Turning into one beautiful looking kit Andy.
 Thanks for looking in and your comments everyone Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Stunning work Andy. Love the contrast of the wood and the paint. Looks amazing. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Hi All More done. After marking out the screw lines a trazillion  1mm holes at around 4mm apart were drilled all over the top surface rear sides and transom. The screws will be represented by 1mm brass wire cut into around 3mm lengths using a mini guillotine. Im currently inserting said brass into there homes right now. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Don't envy you putting all those in Andy  i'm sure it will look great once you have though. Al
And that’s what raises a build from the ordinary, into......something really special! Great build Andy
Regards Gray
I don't envy you Andy drilling all those then cutting and filling with brass. Look forward to seeing them all in place.
ChrisOn the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Thanks for looking in and your comments everyone. Iv had worse jobs and this will be worth it Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,867 Points: 20,918 Location: Northamptonshire, England
Very clever Andy, I hope you’ve got some good glasses, I reacon after you’ve inserted about 20 of them , you’ll go boggle eyed. Mark Regards Markwarren (Mark) Admin
Great attention to detail Andy!  I look forward to seeing all of those brass pins in place. Very nice! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Looks a long and laborious task Andy, but I'm sure it will give a fabulous look to the hull when finished.
Kev
 Hi All Got all the pins in now just lots of tidy up to do before the clear coat is added. For those who may be interested from start to finish for this was:- Working out correct runs, widths and marking out 10 hours. Drilling all the holes 10 hours. Cutting the pins and filling the holes 11 hours. Brass wire used 4 metres. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
That should look amazing once it’s all sanded back and clear coated
Looks great.I am waiting with baited breath for the build of the LEGGENDA E PASSIONE engine.That is such an amazing kit in itself.
Well err thats some time spent on just the holes and the pins. Then you have the rest of the kit you have done and to come. Thats alot of hours Andy. Well done mate done a great job on them and the runs are perfectly straight.
Amazing work Andy, you have the patience of a saint Ken's the name modeling's the game.
 Thanks for looking in and your comments everyone. To get the correct look as it is in the Ferrari Museum it had to be done so sometimes going that extra mile is needed. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Superb work Andy. This model is going to look fantastic! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Great work Andy, what a show piece this will be. Mark Regards Markwarren (Mark) Admin
