Joined: 30/11/2017 Posts: 493 Points: 1,482 Location: South Norfolk
Issue 75 completed: Cover strips for the chainwales fitted and painted black. Unfortunately I didn't pay attention to make the slots a bit deeper on the chainwales body hence some of the deadeye wires were protruding a tiny bit from the slots. I didn't file the excess off because I didn't want to risk the brass wire being snapped. Therefore carefully I sanded slots at the back of the cover strip to accommodate the excess wire. First I was thinking not to use the 1x3 strip, which was said, but 1.5x3 to ensure the slots don't weaken the strip. But then I found the 1x3 was still good enough. Now they will be stored safely until being used. Issue 76 continued: - fitted the moulding strips to the gallery support - the support painted black gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Another very nice update, she's looking really good.... Regards Alan
The chainwales are lookin good!Greetings, Walter
Thanks Alan, Walter. Issue 76 continued: - masking tape removed at the side of the gallery, paint bleeding corrected - stern gun port covers fitted and painted black - gallery support die-cast mouldings sprayed with primer and then black - details with yellow ochre added on one of them. I had a look some pictures about the real ship and this part is actually painted yellow, hence I decided to paint the details with yellow ochre, not gold as said by the magazine. Compared to the magazine I also added details (wheat shapes) into the little "triangle", also painted the whole flower, not only the middle gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Looking good Laszlo Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Issue 76: - Details added to the other side die-cast decoration too with yellow ochre - They glued to place on both sides - Bulwark inner mouldings formed using a jig to allow to dry the strips in shape. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Issue 76: - Inner bulwark moulding cut to size and painted black. I haven't fitted the "uncut" moulding to the bulwark first, as instructed by the magazine, because I didn't want to risk to damage the painted gun ports when the excess are trimmed off. - Moulding pieces were fitted to both sides. I haven't fitted a tiny piece between the last gun port and the cabin wall because this distance on my ship is only about 1-2 mm, compared to the magazine pictures which approx 3-4 mm. I think this won't be noticeable. - Front piece of moulding also cut to size and painted, will be fitted tomorrow. Started Issue 77: - Poop deck painted black underneath the skylight - Skylight assembled - I wasn't quite happy with the paint quality on the skylight pieces, also due to the top being slightly wider/longer than the assembled sides, I decided to sand the black paint off and get the joints smooth. - I filled the inside of the skylight with a balsa block to avoid paint sticking to the inside surface (allow acetate film to stick well) then I sprayed the outside with primer. Black will follow tomorrow. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Lovely work, looking good.... Regards Alan
Skylight is looking good Laszlo, are you using acetate for your windows or something like Micro Krystal Clear ? Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Gibbo wrote:Skylight is looking good Laszlo, are you using acetate for your windows or something like Micro Krystal Clear ? Regards Paul Hi Paul, I’ll use the acerate films provided with the kit. Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Thanks for the good comments. Issue 76 completed: - Remainder of the inner bulwark moulding glued in place Issue 77: - Skylight sprayed black in the morning before I gone to work, this allowed to get it dry until I got home.  - Lower frame added to the skylight and painted black - Acetate films fixed with clear glue - Then skylight glued in place - Middle two transom knees shaped and pained black gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Hi Laszlo, lovely job on the skylight. Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
The skylight is looking good! The speed of your progress amazes me - comparing it to my own!Greetings, Walter
Issue 77 completed: - Middle knees glued in place - Brass wire fitted - Closing strip shaped, painted, brass fitting fixed - I also added two pins (used for planking) to look more realistic that something actually holds the brass fitting in place. - Then the completed strip glued on top of the knees Issue 78 continued: - Belaying pins sprayed with primer, then black. - They fitted to the mizzen mast collar - Flag lockers assembled - Outer knees shaped to fit to transom - Lockers and knees painted black gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Nice update!Greetings, Walter
All looking good... Regards Alan
Thanks Guys. Issue 78 completed: - Outer knees and flag lockers glued in place Issue 79: - Deck handrail assembled - Frame pieces and handrail painted black - Rope handrail fitted around the quarter deck opening - Rear handrail glued in place gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Some excellent work you are doing, looking very nice. Mark Regards Markwarren (Mark) Admin
Very nice Laszlo, coming along a real treat. Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
That`s looking very nice indeed. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
