Hi All, Here is the Avion Red Baron from A/Ls Junior Series of kits.
Especially constructed for children over 8, the Red Baron is assembled in easy stages, and additional skills will be acquired throughout the build making it a perfect entry level build for children from the age of eight.
The model presents an easy and pleasant building that suppose a different and healthy activity during its assembly and they may be the beginning of a passion for the hobby of modeling. Share and enjoy with the youngest children building the series of kits that marked the history.
The basic structure of the model is plywood board made by high precision laser cut, with a fit in system extremely simple and effective.
The kit includes all needed to complete the toy: Laser cut components, instructions on DVD, glue, paints, brush and stickers.
Length: 180 mm
Available here: https://www.model-space....plane-complete-kit.html
This build is to be undertaken by My 15yr old Son Declan. He has built the A/L Pirate ship. http://forum.model-space...spx?g=posts&t=22621
Everything will be done by him. Posted by me on behalf of him.magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Nice start on the beast and looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Great to see this one up and running and off to a great start too, look forward to following... Good luck with the build Dec..... Regards Alan
Great start to the build, nice one.
Nice start Declan, look forward to your progress. Mark Regards Markwarren (Mark) Admin
Thanks for the nice comments guys Declan appreciated them and said thank you.
He has glued a few more pieces to the fuselage this evening. He has found this one easy compared to when his sister struggled doing the Sopwith Camel (similar construction).
Chris and Dec
Hi All, Dec has now finished the build. He enjoyed building this on. His opinion was that this was the easiest of the ones he has done. He enjoyed this one thoroughly.
Chris. magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Very nice indeed Declan, great job you've done.... Regards Alan
Great job Declan, excellent work. Mark Regards Markwarren (Mark) Admin
Great job Declan. very nicely done. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Well built Declan. You've made a great job of her. Another one?
Regards Gray
