7 Pages <12345>»
San Francisco II build by Arek (first wooden ship build) Options
#41 Posted : 02 April 2018 10:05:16
I like. The windows looks great
arek
#42 Posted : 03 April 2018 22:18:22
Thanks for stopping by and comments!
I'm still working on bulwarks, also I added another window!
Have to say I'm really happy from the effectBigGrin BigGrin . All hard work that I put in to fitting LED lights repays now.
Also all dors are almost finished now, ready to be fit!
I have few question about Varnishing and any suggestions or advice would be much appreciated!
For decks I used 4 coats of Danish Oil and I'm happy from the results. Is it ok to use Danish Oil as a finish for rest of the ship?Confused Danish oil seams to be almost odorless and that is a big advantage for me (small childrenCrying ).
I was looking for some odorless varnish but I can't find any information on the web.
Or should I look for some other alternatives?
Thanks,
Arek
#43 Posted : 03 April 2018 23:05:56
those hinges look good and sturdy, doors look fab
nice job
#44 Posted : 03 April 2018 23:22:49
Very nice indeed Arek, I love those doors.....Drool Drool .. As for Danish Oil, I've used that on my builds and to date it hasn't given me any problems at all. Good thing about it is it penetrates and protects and nourishes the wood but it will not give you a hardened protective coat against scuffs or scrapes. That shouldn't be a problem if the finished build is displayed within its own display cabinet.....Cool Cool .
#45 Posted : 04 April 2018 00:23:23
Looks awesome mate, I use danish oil on all my builds.
Danish oil is a hard drying oil, meaning it can turn into a solid form. It can provide a hard-wearing, often water-resistant satin finish, or serve as a primer on bare wood before applying paint or varnish. It is a "long oil" finish, a mixture of oil and varnish, typically around one-third varnish and the rest oil. usually made from Tung Oil.
You can also stick parts to it with superglue no problem.
Gibbo
#46 Posted : 04 April 2018 00:25:33
Hi Arek
Your lighting looks great and you've done fantastic job of those doors, looking forward to seeing more.
Paul
#47 Posted : 04 April 2018 01:02:32
Looking good and even better to see you back on the forum.
Cool Cool Cool Cool Cool
Keep up the good work
Love Love Love
arek
#48 Posted : 04 April 2018 06:26:58
Thank you all for comments and a word of advice.BigGrin
So Danish oil for the rest of the build!Cool Cool
Have to say that after finishing dors I'm tempted to also replace all cast metal gun ports. Probably I will create some kind of jig for that job.
Anyway I will keep updating my log regularly.
#49 Posted : 04 April 2018 07:56:01
Nice work on the doors, they look great.ThumpUp
arek
#50 Posted : 06 April 2018 12:17:07
Just a quick update.
Because i left my build for long time I forgot about balsa!Angry
My plan was to add some balsa before finishing bulkheads but is never to late for that. Now I just have to be more careful when sanding down.
Lesson learn for the future!BigGrin
I started from the bow in the first two ribs. After doing some sanding I realized that I probably need more between second and third rib.
Anyway that is my progress so far, looks like busy weekend ahead in my shipyard.LOL LOL
arek
#51 Posted : 08 April 2018 17:53:13
I had a very productive weekend!BigGrin Sanding and fairing the hull is finished also all dors are fitted.
I was expecting that sanding stern section to get the desired shape will be more difficult, after all wasn't that bad and I'm really happy from the end resultsCool Cool Cool
There's still one more deck to be fitted but it need some attention.
On the stern I cut holes for the windows in the Captains cabin. Now I have to make windows and dors before finishing the stern.
Any comments or suggestions are more than welcome!
Gibbo
#52 Posted : 08 April 2018 21:37:31
Nice job on the sanding Arek, that's a great base to continue with.
Paul
#53 Posted : 08 April 2018 22:20:44
Nice fairing you've done there. Looking great.
#54 Posted : 09 April 2018 09:00:45
Some really nice work being done here, she's looking great....Cool Cool
arek
#55 Posted : 11 April 2018 21:13:05
Thanks all for stopping by and kind comments.BigGrin
The last part of the deck is finished and fitted.
Instruction says to use 1.5x3mm strip on the edge. I decided to change this little bit.
From the sharp blade I made some kind of jig and simply scrapped the strip until I got half dowel shape
I have some mahogany wood die so I used that on the bottom of the deck that is hanging over.
Also I cut off the last strip for the bulkhead to fit nicely under the decking part.
Final result.... probably not much of a difference but I think it look nice and neat. I might use this method to finish some other edges.Cool
Finally windows and dors for captain's cabin are ready. I took me few attempts for windows as I changed size and shape few times. For now I'm moving to stern part and then I should start plankingCryingCryingCrying
#56 Posted : 11 April 2018 21:15:30
BigGrin Very nicely done looking forward to seeing more of this build Cool
Martyn
Gibbo
#57 Posted : 11 April 2018 23:54:40
Verey nicely done Arek
Paul
#58 Posted : 12 April 2018 11:12:30
Some very nice touches being added Arek, nicely done....Cool Cool
arek
#59 Posted : 12 April 2018 19:56:40
I'm hope for more of touches like this in the future Cool More time I spend on the build more ideas cumming in to my head.... I'm trying to personalize my ship but also test my skills before I move to some bigger build.
I'm actually already planing to start collecting some other model but simply cannot decide what to chose.Confused Confused For the moment on the top of the list I have Solei Royal or Sovereign of the Seas. Solei Royal is in the bigger scale so might be easier working on some details...
But that is not going to happened until at least Autumn, so far I have planking ahead of me and I'm really afraid to start this part.Crying Crying Crying
I looked on many tutorials and videos about planking but being honest the more I read, the more I'm confusedBigGrin
As always thanks all for stooping by. I should have some update after the weekend.
Arek
Gibbo
#60 Posted : 13 April 2018 00:08:39
arek wrote:
I'm hope for more of touches like this in the future Cool More time I spend on the build more ideas comeming in to my head.... I'm trying to personalize my ship but also test my skills before I move to some bigger build.
Hi Arek
Planking is quite straight forward from the middle of the ship working up toward the gunwhales, a lot of the time depending on the ship you are building you wont have to make too many adjustments as mostly it's plank on plank, for the first time around it is a daunting prospect but i would suggest you do these sections first, that will give you the knowledge, know how, and confidence to work on the sections from the middle of the ship to the keel where you may want to add droppers and stealers to your hull, i don't know if you know what these are or not but i would suggest looking at the official HMS Victory build and the related video diary on youtube and is very useful as a guide for any ship you build, they explain these sections very well, on my first ship i just slapped them on not knowing what droppers and stealers were at the time but that didn't matter as i was painting it, and on my second i gave it a go and although it's not perfect i'm quite happy with it and moreover i surprised myself, just give it a go my friend i'm sure you'll do a stand up job.
Paul
Arek
7 Pages <12345>»
This page was generated in 0.178 seconds.
