23 Pages <12345>»
John's Shambles Options
#41 Posted : 06 March 2011 20:18:27
hi john,that's too complicated for me,I'll do a deal here,you take me to greece and I'll build it for you.BigGrin
Son of Bulwark
#42 Posted : 06 March 2011 21:52:58
z8000783 wrote:
I need a little help in the form of a favour from someone. I have decided to put together a new jig to use while I plank the lower hull however, I am in the UK for 3 months and my build is in Greece so I need some measurements taken. Here they are and as usual, any other tips very gratefully received.
1. What is the height from row 12 of the planking to the top of rib/frame 15
2. What is the height from row 12 of the planking to the top of rib/frame 26
3. What is the distance between ribs 15 and rib 26
4. What is the width of the ship at the top of rib 15 i.e., distance between the tops of the same rib across the beam
5. What is the width of the ship at the tops of rib 26
I might need some more as I go.
Many thanks.
John
Hi John! Cool
Answer are around about:-
1:- 25mm
2:- 50mm
3:- 451mm
4:- 128mm
5:- 113mm
Hope this help you mate!
z8000783
#43 Posted : 06 March 2011 22:55:34
Groups: Unapproved
Brilliant and many thanks. Tickets for 2 weeks in Greece on their way.
John
z8000783
#44 Posted : 20 May 2011 10:29:27
Groups: Unapproved
7 days to go and I'll be back looking forward to planking the Hull.
Have been busy in the meantime building a jig to lay the model upside-down. I haven't finished the top planking yet but decided to move on so as not to do any damage to my labours.
Are there any downsides to doing this I am unaware off?
As always thanks guys and I suspect this thread may get busy again over the next few weeks - or months.
John
#45 Posted : 20 May 2011 11:35:22
You might find this topic useful
http://forum.model-space....aspx?g=posts&t=2394
z8000783
#46 Posted : 20 May 2011 12:16:35
Groups: Unapproved
Thanks Tomick, looks like no major issues with doing this then.
John
z8000783
#47 Posted : 30 May 2011 17:36:28
Groups: Unapproved
So at last, have put knife to wood for the first time since February, and finishing of the middle deck gun ports.
Next step will be using my new curling tongs to help plank the hull. Fair bit of work over the next few weeks I think.
I have missed being here and working on her, I must say.
John
Son of Bulwark
#48 Posted : 30 May 2011 20:38:49
Welcome back John! Cool
Your ship has missed you!
Good luck with the curling tongs, but don't curl the planks to much, your hull doesn't want a PERM! Laugh I'll look forward to seeing your next pictures mate.
z8000783
#49 Posted : 02 June 2011 15:49:50
Groups: Unapproved
OK all those ahead of me put down the sails for a moment and take yourself back to last year. I am sure this has been covered but I just want to check before I continue.
Just finishing off cutting out the gun ports on the middle gun deck and have drilled as per the pic. Notice the holes are in the main support strips and not the extensions pieces. They are all 1mm to 2mm below the top. I can see how some are close and would break the top but none are actually in the extension piece.
I am really just looking for confirmation that everything is OK to continue.
Thanks guys.
John
#50 Posted : 02 June 2011 16:00:59
The extension pieces stop the drilled holes breaking out and appear to be drilled ok, just make sure that the pieces are securely glued so as not to come loose later on when inserting the dummy barrels.
z8000783
#51 Posted : 02 June 2011 16:05:51
Groups: Unapproved
Thanks Tomick. All solid and OK.
Onwards and upwards.
John
z8000783
#52 Posted : 05 June 2011 18:06:59
Groups: Unapproved
Just to say I have been busy while away from the ship and to say thanks to Darron (again) for the dimensions.
The jig is to help me plank the hull so I had to leave the rest of the top planking for a while. Not the best carpentry in the world but it only cost £2-£3 pounds. Ready for the 'Long Walk' now.
John
tom.ganc
#53 Posted : 05 June 2011 21:59:47
WOW
Nice jig Drool
It's a shame I didn't build mine like that :)
Good luck with lower hull Cool
z8000783
#54 Posted : 07 June 2011 17:58:05
Groups: Unapproved
Thanks Tom, have finally made a start, first plank laid.
John
z8000783
#55 Posted : 10 June 2011 13:32:42
Groups: Unapproved
I have a question way back in ancient history at Issue 32.
It says that you start the lower planking at 18, 17, 16 & 18 again fixing the centre planks and bows.
The first 3 I can follow but surely the last one overlaps the other 3 before the stern planks have been laid as in issue 33.
Am I missing something here?
John
#56 Posted : 10 June 2011 15:30:09
The first three layers continue down the sides of the hull and the planks extending back to frames 25, 24 and 23; have a look at the photos in my diary build for 32.
z8000783
#57 Posted : 10 June 2011 16:09:33
Groups: Unapproved
Thanks Tomic, I see now.
On another point, in the instructions it talks about using a dropper very soon after the starting the lower hull, but I don't even need to taper the first plank and probably not the second either.
Looking at Darron's build the first dropper doesn't appear until the 5th and 6th layers and I think mine will be similar.
Just confirming this is OK.
John
#58 Posted : 10 June 2011 16:17:03
Just as long as you don't forget, because it will come back to haunt later on.
z8000783
#59 Posted : 10 June 2011 16:19:20
Groups: Unapproved
OK Ta, so long as I let the planks lay straight and then do what required I guess it will be OK.
John
z8000783
#60 Posted : 12 June 2011 12:09:40
Groups: Unapproved
Just thought I would take a break from planking and work on the barrels for a while. Here's a great little tool for cutting the ends.Not perfect but will look OK once stained I think.
Machine Mart
John
Guest (5)
23 Pages <12345>»
This page was generated in 0.179 seconds.
