While waiting for that new wind shield to arrive I finished off most of the bits and pieces that hang off the back of this DFV. The polished pipes and other small parts are bagged-up and waiting ! Malc.RM1 attached the following image(s):
Lovely work as always and getting ever closer to that finish line. This is going to look fantastic when complete, well done on yet another great update Malc.
Kev
Got the engine attached to the body. Quite a difficult job to get the power unit aligned and at the correct length for the rivets to locate in the body. Had to do some metal removal Malc.RM1 attached the following image(s):
Extra details added, the battery cables and some work on the coolant pipes.RM1 attached the following image(s):
Lovely work as always Malc, really looking like a classic race car now! I'm really enjoying your build diary Malc and look forward to each new update from you.
Although expensive for the scale, I am so inspired by your model that at some point this year I fully intend to take the plunge and buy a MFH 1:20 kit for myself!
Kev
 Very nice work Malc and the extra's make all the difference Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks for the comments guys.
@Kev. Can't wait to see the result that you would get from one of these MFH kits. . Malc.
Thanks for that compliment Malc, very much appreciated. I don't expect to buy a kit until later in the year but who knows it may be a bit sooner!
Kev
Stunning detail and a real credit to your enthusiasm and skills
Thanks for the encouraging comments.
I've now added the hosing to the engine. This is the MFH metallic hose which is solid white metal with a mesh pattern embossed. A bit like rolling a solder wire on a rough file ( which I've done in the past ! ). First time I've used it. Cut to length and drill 0.5mm in each end to take a fixing rod. A bit tricky !! Malc.RM1 attached the following image(s):
From the other side.RM1 attached the following image(s):
Really top work Malc  this is going to be museum quality i think  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Very nice work Malc, fettling those hoses take a little getting used to but they certainly look the part when fitted Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks Phil, really appreciate the comments. Malc.
Lovely work Malc, she’s really going look something when finished. Mark Regards Markwarren (Mark) Admin
Stunning detail and beautifully put together as always Malc, very well done - keep these updates coming!
Kev
Loving your build Malc keep up the good work. All the detail is amazing Regards Gray
A little more done... The wheels are very nice turned parts. I roughed up the tyre treads for a better look. Malc.RM1 attached the following image(s):
 I do like the way MFH put there wheels together as they look correct when assembled. Looking great and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Got the rear end pretty much completed. Exhaust pipes added. This has to be done when everything else is in place otherwise the plumbing would be impossible. RM1 attached the following image(s):
Guest (6)
