Issue 65 missing parts Options
pbudden
#1 Posted : 24 March 2018 16:16:23
Rank: Newbie
Hi,
I just received my monthly package and was able to progress to Issue 65 where I discovered there were no parts in the sealed package with the magazine. Confused
Planning to call C/S on Monday about this. Is this a one off or has this happened to several builders?
#2 Posted : 24 March 2018 17:41:16
hi
Its a one off just ring C/S and a replacement will be sent
semaj
#3 Posted : 25 March 2018 00:06:24
i found the white diffuser in my issue 65 was damaged - looks like its somehow melted at some point (badly out of shape and marked, does not fit at all), so i also require a replacement. these things happen, cs will replace. shall call them on monday when lines are open again.
semaj attached the following image(s):
Building:
Complete:
stuk71
#4 Posted : 26 March 2018 14:24:48
Received mine today - all fine
These must be isolated incidents unfortunately.
semaj
#5 Posted : 26 March 2018 20:55:03
seems that way. as i said, these things happen. just pointing it out more than anything. phoned CS earlier and ordered a replacement.
shame they have to send the whole lot when i only need 1 part.
Building:
Complete:
This page was generated in 0.149 seconds.
