16 Pages <1234>»
MWG build diary of the iconic 007 DB5 Options
#21 Posted : 09 June 2011 22:44:00
After what has gone before, what with me messing about with photos etc,I have decided to recap this build from the beginning
This Partwork comes with parts list covering all 85 issues together with 4 large work sheets with exploded view of all parts, and when they are due. Also supplied is a detailed magazine with instrutions and features.
It also has a chart showing all screws and their sizes.I have enclosed a picture on this post
007 DB5 034.jpg (2,876kb) downloaded 56 time(s).
#22 Posted : 09 June 2011 23:28:40
Part 1) is Radiator grille, Aston Martin badges; Bullet proof screen.(put these away untill later.)
Part 2) is the drivers seat; front bumper and rotating number plate. I built the front seat (stored the number plate
part 3) Bonnet and Superleggera logo (which I stored)
007 DB5 022.jpg (3,637kb) downloaded 63 time(s).
007 DB5 023.jpg (3,376kb) downloaded 51 time(s).
007 DB5 025.jpg (1,581kb) downloaded 49 time(s).
007 DB5 035.jpg (2,585kb) downloaded 62 time(s).
#23 Posted : 09 June 2011 23:59:01
Part 4) Oil cap;cylinderhead;fan;fane belt;timing case.I built these items and currently doing some enhancing mods.
Part 5) A Tyre; control console assembly. ( I stored )
Part 6) Drivers wing mirror;Weapons draw base and cover;Silencer;Gun barrel; Gun stock;Throwing knife;Gun;Genade;Roof panel ( I stored )
007 DB5 029.jpg (2,032kb) downloaded 47 time(s).
007 DB5.jpg (1,620kb) downloaded 42 time(s).
007 DB5 036.jpg (2,636kb) downloaded 48 time(s).
#24 Posted : 10 June 2011 00:57:29
Part 7) Drivers seat ajustor; (I fitted to seat)Left engine block.
Part 8) Gearbox;Sump;Clutch slave cylinder;Starter motor.(Built the parts), painted the starter motor black and silver.
Part 9) Exhaust manifold;Ignition leadholder and leads;Distributor cap and leads;Carburettor assembly.(fitted Manifold,ignition lead holder and carburettor assembly,)see last engine photo. The distributor cap came with 4 leads, pulled out the leads and modified the dizzy to take the 7 leads required ( 6 cylinder + 1 to the coil).
Part 10) Right and Left camshaft cover and breather cap assembly;cross shaft assembly; Radiator hose (all these items fitted, please see photo of cylinder head)
007 DB5 017.jpg (3,250kb) downloaded 52 time(s).
007 DB5 024.jpg (1,973kb) downloaded 36 time(s).
007 DB5 038.jpg (1,686kb) downloaded 35 time(s).
007 DB5 031.jpg (1,830kb) downloaded 39 time(s).
007 DB5 037.jpg (1,792kb) downloaded 40 time(s).
007 DB5 039.jpg (1,709kb) downloaded 33 time(s).
007 DB5 032.jpg (1,928kb) downloaded 41 time(s).
#25 Posted : 11 June 2011 01:41:40
For those of you who like instant photos they have been added to this thread'
#26 Posted : 11 June 2011 17:38:56
Parts 11-12-13-14 and 15 cover the last bits of the engine and bulkhead.
One thing I noticed straight away THERE IS NO DIPSTICK! so I decided to put that right and add one!!
After some research,I new what it was like, and where it fitted on the engine, I then went about getting the parts
I first got some 1 mm brass tubeing, and piano wire as the actual measure part, I then needed a chrome collar to put between the handle of the stick and the tube ( for this I chose a servo screw from a model shop ) Here is the result:-
#27 Posted : 11 June 2011 18:14:58
I will place some thin oil in the tube when the car is finished, and I will be able to "check the oil"
The next job is to "Mod" the alternator, by giving it a real looking magnet and fan.
Ok lets do it.first you will see the engine, end on showing shots of the two halves of the engine screwed together, and the fly wheel assembly (the red fan etc) the alternator is on the right side as you view the photo.
Next photo is the alternator and pully. the object of this "mod" is to make and fit a fan with blades, so I took the base of a been can, and cut out (with sharp scissors)a small circle.
Next, again with sharp scissors I cut the blade of the fan and fitted it to the alternator. more to come next time------------!!!!
#28 Posted : 12 June 2011 20:42:04
The tools I am using on this build are as follows:-
1) A pair of gloves to protect the surface of the model,from grease etc.
2) A good set of large handled small screwdrivers.
Adhesives are not required for this build.
If you are doing "Mods" to this build ( Enhancments do lend themselves to this build) you will require other tools.
#29 Posted : 22 June 2011 01:36:48
The next issues cover the bulk head around the engine.
I modified the radiator expansion tank by fileing off the plastic over flow pipe and fitting a 1mm thick real piece of tubeing.
#30 Posted : 22 June 2011 01:44:24
The issues upto 22 covered all the parts for the 2 front wheels, this includes the tyre, 3 parts of the wheel, the brake caliper and disc brake plus screws ( I will fit air valves to all wheels as a mod more about that later.)
#31 Posted : 23 June 2011 22:36:25
Hi again, issue 23 contained the steering wheel with wires conected for the working indicators and horn, here it is:-
#32 Posted : 23 June 2011 22:43:23
Issue 24 contained the Dashboard with built in switch (on the bottem right of the dash ) to light up the dash board.
I will cut out the glove box latter on, so it will be a working glovebox with champagne and glasses, Here it is:-
#33 Posted : 30 June 2011 09:07:53
In issue 25 we received:- the Dashboard mount (this is an electric part that contains the bulbs to light up the Dashboard) next comes the left air vent unit and left air vent cover, together with left air vent switch.
Nothing will be done with these parts yet.Please see photos.
IAN
#34 Posted : 30 June 2011 09:16:19
Hi MWG.
The build is looking very good.
You sure have lots of patience, for this hobby.
Best regards,
Ian
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
#35 Posted : 30 June 2011 09:22:30
Thanks IanLOL
I have a few more "mods" to do before we reach 35 ( This is when we fit all the first 34 issues to the front floor pan )
#36 Posted : 07 July 2011 23:42:06
Hi every one, this week is week 26, and its continuing the dashboard, we have control front plate,rear air vent unit and cover,dials, light switch and lighter.
#37 Posted : 07 July 2011 23:48:07
WHAT DO YOU THINK OF THIS?BigGrin this is a POCHER tool kit and it is 1/8 scale like the DB5, I had to have it!Drool All wood and metal construction, will go great in the boot of the DB5LOL
#38 Posted : 13 July 2011 20:08:57
Hi this is issue 27 and the parts are Glove compartment lid,Ignition switch unit,Ignition keys, Clear control unit, Bonnet release handle.We now have all the parts for the Dashboard with this issue, here we are :-
#39 Posted : 16 July 2011 18:25:04
Today I have decided to do some more work on the engine, I am going to "mod" gaskets for the exhaust manifold and the 2 cylinder head covers.
My reseach shows a copper gasket on the real DB5,and so I have purchased an A4 orange plastic card:-
#40 Posted : 16 July 2011 18:29:27
I then cut 3 pieces of the plastic card to reproduce my gaskets ( I do not want these gaskets to shout out at me when they are fitted, just a hint to know that they are there ):-
16 Pages <1234>»
This page was generated in 0.398 seconds.
