106 Pages «<9293949596>»
#1861 Posted : 16 March 2018 08:48:02
Rust effects around the port saddle tank lids.
#1862 Posted : 16 March 2018 08:48:31
Port aft section.
#1863 Posted : 16 March 2018 08:49:38
Port amidships draught marks located on the saddle tank.
#1864 Posted : 16 March 2018 08:54:51
That concludes this weeks reworking. In addition I have included a couple of black and white photos of the bow to better see the paint effects when viewed with an historical eye.
#1865 Posted : 16 March 2018 08:55:54
Another view of the port bow in b/w.
#1866 Posted : 16 March 2018 08:57:55
Overall i'm happy with the results and can start making plans for planking the upper casing.
Thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin
#1867 Posted : 16 March 2018 10:36:38
lovely work Phil, spot on with the rust effects.Love
#1868 Posted : 16 March 2018 11:19:50
Thanks very much Mark!Cool Happy now I've got the varnish on to seal those effects instead of accidentally wiping them off.Blink LOL
#1869 Posted : 16 March 2018 12:54:41
Looks stunning Phil, detail is very impressive....Drool Drool
#1870 Posted : 16 March 2018 13:40:46
I think you`ve nailed the weathering PhilDrool Drool outstandingBigGrin regards PhilCool
#1871 Posted : 16 March 2018 14:45:31
Fantastic work Phil, you are getting some very realistic effects from what you are doing - a stunning model, well done mate! Drool Cool ThumpUp
#1872 Posted : 16 March 2018 15:46:38
Great job Phil Cool she looks like she's been around a bit now.
#1873 Posted : 16 March 2018 15:54:28
Thank you Alan!Cool Glad you like the updates, painting accidents and all.
#1874 Posted : 16 March 2018 15:55:52
Thanks very much Phil!Cool A little set back painting wise, but it's turned out alright in the end.
#1875 Posted : 16 March 2018 15:58:04
Thank you very much Kev!Cool As I've mentioned before, a couple of set backs painting wise, but I'm now happy with the way the boat is looking.
#1876 Posted : 16 March 2018 16:03:11
Thanks for looking Al!Cool Glad you like the effects. You're right, these boats had plenty of sea time and minimal time in dock, so I wanted to reflect that on this model.
#1877 Posted : 22 March 2018 23:44:05
This weeks update of my U230 U-boat build log sees the start of the planking on the upper casing.
The wood I chose is mahogany, the same used on the actual U-boats, bought from Cornwall Model Boats. Supplied in veneer strips; 1 metre long, 2.0mm wide and 0.5mm thick.
From a width perspective they are slightly oversize at 2.0mm, ideally 1.5mm wide [3 inches actual] would of been better.
I tried to cut some lengths down to this width with mixed success, removing 0.5mm with a craft knife. Generally the cut would start off okay only for the grain of the wood to take over giving a ragged edge.
In situations like this, practicality overrides authenticity and I decided to leave them as they were. In all honesty, it's not really noticeable and still maintains a 'fine scale feel', which is an underlying theme I intend to continue.
The other difference between the planking on U-boats compared with ship decks is a small gap between each plank. This is to allow the oggin [the sea], to drain away; especially important in cold, icy conditions to prevent the crew from slipping overboard.
The gap I used between the planks is 0.5mm [1 inch actual], which is true to scale. Several small pieces of 0.5mm thick plastic sheet were used as gap gauges.
The attached photo shows the second plank in position with spacers in place.
#1878 Posted : 22 March 2018 23:46:47
From above.
#1879 Posted : 22 March 2018 23:47:42
Another photo showing the spacers in position for the second plank.
#1880 Posted : 22 March 2018 23:51:39
The next batch of planks fitted. I used PVA glue for adhesive and several small metal off cuts as weights to hold the veneer strips down.
I did experiment with pins to hold the strips, but due to the fact these veneer strips are so thin in depth [0.5mm], they would just split when pinned.
This page was generated in 0.389 seconds.
