38 Pages «<89101112>»
Garth's Black Pearl Options
#181 Posted : 27 February 2018 06:35:44
Hi Guys,
Thank you all for looking in and I sincerely appreciate all the kind words.
(Well spotted Trevor - the Windhoek Draughts really go down well!!!)
#182 Posted : 02 March 2018 11:44:32
Hi All,
A small update today. I assembled the gratings and their frame. I decided to solder the brass components, simply for practice. Supergluing them would have sufficed.
The timber parts of the frame are very thin and flimsy. Once glued I put some weight on to hold them down. Once dry they were primed and painted matt Black. I’ll do some dry-brushing to weather them at a later stage.
#183 Posted : 02 March 2018 18:41:33
Another very nice update Garth, all looking good....Cool Cool
#184 Posted : 02 March 2018 19:11:44
Nice work Garth.Love
#185 Posted : 02 March 2018 20:24:47
Looking great mate
#186 Posted : 09 March 2018 10:38:48
Hi Guys,
Thanks for looking in. Your comments are much appreciated.
#187 Posted : 09 March 2018 10:55:06
You are doing a superb job on this BigGrin well doneThumpUp ThumpUp regards PhilCool
#188 Posted : 09 March 2018 14:22:54
Hi Phil,
Thanks for looking in and for the kind words.
#189 Posted : 09 March 2018 14:29:04
Hi All,
A decent update this timeBigGrin
Just a note to anybody following my build with the intention of building your own Pearl. I am not following the instructions as they are presented in each issue. As I have all the parts, I jump around and try to complete similar processes in one go. I will try to elaborate where I have deviated, but please forgive me when I do not.
Issue 31 & 32 have us fitting parts 99 & 100, I’m leaving them off until I have completed the planking – they are just asking to be snapped off!!!
A note on the planking. It is not mentioned in the instructions, but an electric plank bender really makes life easier. I made mine using an old soldering iron with a socket attached to the tip. Once again thanks to Gordon for his advice on turning a soldering iron into a plank bender. I had on old offcut piece of Kiaat that became the former.
My planking process is roughly as follows: chamfer the edge with a small Box Plane if necessary, test fit, trim and sand, soak in water for a couple of minutes, place the plank over the desired radii and gently form the curve by running the soldering iron over the strip. (I assume that the heat from the soldering iron boils the water which intern creates the steam required to soften the fibres enough to allow them to be bent without braking)
http://forum.model-space...spx?g=posts&t=23060
I use white glue to glue the strips down and therefore don’t wait for them to dry. The advantage of this is that the damp planks are much easier to manipulate.
Further consideration is the planking sequence in the instructions. They tell us to plank the starboard side and then in the next issue, the port side. This goes against everything I have ever read regarding planking. In order to prevent the hull warping, planking should alternate between port and starboard.
Down to business. Parts 78 and 81 must be scored and bent to take the shape of the rib, Part 14. Started with the first three rows on both upper & lower planks. I stained the planks that will be visible between the decks.
I also drilled hole through the keel for wires.
Well, a lot said and only 3 rows of planking - but its a start.LOL
#190 Posted : 11 March 2018 22:11:05
BigGrin Looking Fantastic Garth.Cool
#191 Posted : 11 March 2018 23:46:08
Very interesting and looking good Garth.....Cool Cool
#192 Posted : 12 March 2018 14:16:36
Great update`s GarthBigGrin looking fantasticDrool regards PhilCool
#193 Posted : 16 March 2018 06:27:09
Hi All,
Thanks again for the kind words.
Started planking Starboard side, again alternated between Port & Starboard after every couple of rows. I left an opening below the lower deck which I intend to fill with ballast.
Gibbo
#194 Posted : 16 March 2018 10:53:10
I like what you're doing with this Garth, looking forward to more.
Paul
#195 Posted : 16 March 2018 12:49:31
Looking good Garth, very nice progress....Cool Cool
#196 Posted : 23 March 2018 06:53:48
Hi Paul and Alan,
Thanks for looking in and for the kind remarks.
#197 Posted : 23 March 2018 06:59:44
Hi All,
Completed the planking.
I added strip between decks, this is not indicated in the instructions, but I think it looks nice.
This completes Issues 35, 36 (7.5 hours)
#198 Posted : 23 March 2018 13:20:25
Nice work Garth, looking excellent.Love Drool
#199 Posted : 23 March 2018 14:53:20
Hi Garth.
some nice neat planking. love the lights.Cool BigGrin Drool
#200 Posted : 23 March 2018 15:01:06
Hi garth
Loving all the action going on below decks, and the lighting is cool.
Great job.
This page was generated in 0.232 seconds.
