Thank you Graeme, Gray and Alan for looking in. Mark Regards Markwarren (Mark) Admin
 Rank: Pro        Groups: registriert
Joined: 13/03/2012 Posts: 306 Points: 847 Location: Germany
Hi Mark It is always nice if there is someone from whom you can learn!. Great what you do with a kit! amazing work! Forum Support Team http://www.model-space.com/de/
Mark you are doing a brilliant job  love the detail  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
This is coming along a treat Mark, looking forward to seeing more, when done are you planning to put up a youtube vid so we can hear the sound effects ? Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
 Very nice work Mark looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thank you guys for the kind comments and your support. Paul... Once I have finished the model, I will be putting up a video to show the finished diorama with sound effects. I’m still at very early stages on the base/diorama, but I know want I want it to look like and I have ideas of how to hide the supports with the cables in, so it looks as if it is floating in mid air. I’ve got a long way to go with this, so it will be a while before it’s finished. Regards Mark Regards Markwarren (Mark) Admin
Looking Very good Mark. look forward to seeing your progress Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Many thanks Ian Mark Regards Markwarren (Mark) Admin
Looks really good mark. Your weathering and painting are spot-on. Im not a big Starwars fan (New hope onwards are the best IMO) but definitely like this.
Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Rank: Pro     Groups: Registered
Joined: 26/12/2012 Posts: 140 Points: 418 Location: Plymouth
Love the detail in your paintwork it really brings the look alive and the wear and tear.
Thank you all for looking in.
The next instalment was some more tweaking on the two engine parts. The first thing was to solder the copper cable to the front motor that will turn the fan on the engine intakes on both engines. Once this was done, I glued the front ends to the main engine body and lining it up, so the two parts matched. The two engine parts were then masked off and the front was air brushed with yellow paint. These were then allowed to dry for an hour, before carefully rubbing over with a cotton bud revealing some of the metalcote paint beneath. The energy binder caps were next to be attached. These come in two halves and are about the same size as the circumference of a regular pencil, why they made them in two halves for how small they are, god only knows. The two halves were glued together, and some sanding was needed to get rid of any join and seams. They were then painted and attached as shown. The final picture shows the exhaust vent flaps being attached. These are hinged so they can be opened in any position. I then started to add some of the external pipes on the outer engine.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
These pictures show the cables and pipes attached. I then used some metal polishing pigment to bring out the detail on the engine. The under-carriage stabiliser was then glued and attached to each engine, feeding the cables through the holes ready for connection to the PCB board. The rear exhaust part is still to be done, along with some more detailing on the engines. I will probably not attach the three steering arms on each piece just yet, as I have a long way to go on this model and I don’t want them to get damaged.
So, until next time, happy modelling.
 Very nice work and dirtied up a treat Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking fab, excellent work Mark.... Regards Alan
Thanks Alan, Andy. I appreciate your comments. Mark Regards Markwarren (Mark) Admin
I love not only the detail but the the fact the level of workings inside in relation to the size of it.
godan61 wrote:I love not only the detail but the the fact the level of workings inside in relation to the size of it. Many thanks for your kind words. The pod itself is quite small, and I will have to use SMD lights with that part of the build, but I do like a challenge. Mark Regards Markwarren (Mark) Admin
Flawless paint work as always. SMDs for the main body--ughh break out your magnifying glasses for those!!!!
 Great job on the paint work Mark Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Back with the podracer diorama. Here you can see, I have primed the two halves of the pod. The bottom half came in two sections and these were glued, filled and sanded to get rid of the seam line. The hole was also drilled in the bottom as this is where the cables will run for lighting. The third picture shows the hollow rod in place. I have also made a notch on the underside of Anakin’s seat, this is where the cable will run as the hole is directly beneath. You can also see I have made a hole in the front cockpit for the same purpose.
