Very nice clean work with the etch. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 19/05/2015 Posts: 1,419 Points: 4,272 Location: Darmstadt, Germany
Almost forgot it's Wednesday. Scharnhorst issue 32  As announced we finally begin planking the middle of the hull with the 32 first planking strips. At 3mm width these are the slimmest planking strips I've ever used, making them both the easiest and most tedious to work with. Easy because it's really simple to have them follow the lines of the ship without watering or prebending. Also chamfering becomes unneccessary. On the other hand, you have to put down a lot more strips than usual. Tall ship builders might be wondering why the strips are not layed down in a pattern. With the strength of the MDF hull skeleton theres no need to pattern for more stability and as the hull is made of steel plates in the original anyway we actually don't want a pattern of planks to show.
Great start to the planking  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Very tidy work on the planks. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Your planking looks very tidy, nice work.
Thanks, guys. Scharnhorst Issue 33  When it comes to planking there are two very different groups present in the ship model building community. There's the ones like me, that find an almost meditative quality in the work involved and then there's the second larger group of ship builders that absolutely DESPISE planking getting increasingly annoyed at doing the same task over and over again with hardly any progress seen, oh God, why won't it END? To accomodate the second group, this kit has sporadic intermissions where we do something different to break up the planking work a bit. Here's the first one already. With this issue we clad the area around the drive shafts with preformed ABS parts. Like the stern and bow, this area would be very very hard to build out of wood. We also extend the keel a bit with a wood strip we received a few issues ago.
Scharnhorst issue 34  More planking on the middle hull section. This issue teaches us about the difference behaviour of wood strips on a flat surface versus a curved one.
Love it or loath it that planking looks very neat. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Lovely plank work greyhawk. Its growing slowly . Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Scharnhorst issue 35  Finishing up planking of the middle section of the hull, we learn how to cut strips to size so they will fit in gaps. Afterwards all the nails are pulled and the planked section is given a once over with sandpaper to smooth it. We've reached the 25% landmark in the build, so it's time to have another look at the whole thing put together so far.
She`s looking good  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Joined: 14/04/2015 Posts: 238 Points: 716 Location: Newcastle
Great work Are the bow, stern and propeller sections permanently attached at this point? If they are won't that complicate the planking around those areas?
Great work, looking very good. Mark Regards Markwarren (Mark) Admin
Your last photo really gives the idea of the scale, she’s a biggy Looking good. So keep up the good work. Regards Gray
Thanks guys michael.rolph wrote:Great work
Are the bow, stern and propeller sections permanently attached at this point? If they are won't that complicate the planking around those areas? They are. It'll certainly get interesting
Nice work, looks a very similar build format to the Bismarck
Nice update! She really IS big!!Greetings, Walter
Yeah, it's the same group of designers who did the Bismarck partwork Scharnhorst issue 36  We start planking the second section of the hull. Now that we know HOW planking is done, the instructions speed up things a bit and so we lay down about double the amount of strips then we did in the sessions before.
Really coming along great  nice work  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Nice tidy work, coming on very nicely. Mark Regards Markwarren (Mark) Admin
