 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,192 Points: 15,725 Location: ipswich
Thanks Rich. I'm just fiddling about with bits, awaiting the next batch. One thing I have noticed, many series 1 E Types with the 3.8 engine had a temp sensor in the expansion tank that went to the fan. I thought it would add a bit of extra detail to fit one. Very straightforward - an old small metal fitting from my bits box, two wires and a bit of heat shrink. Sorted. roymattblack attached the following image(s):
 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
A thing of beauty. Nice work Roy.
Great work Roy, all that extra little detail makes all the difference Mark Regards Markwarren (Mark) Admin
Looks so clean and untouched Roy  any weathering with this  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
I'm not going to weather this one. It's a Jaaaagggg and should be showroom. Only a small bit done here as I'm waiting for the next batch of bits. The heater box actually has a control valve on the 'engine' side and a return spring mechanism on the outside. I decided to add them just to fill a small empty space. The spring is made from fine wire wrapped around a dressmakers pin. The arm and bracket are plastic and the rod is part of a pin. I've also added some period correct decals to the shock absorbers. Next??? roymattblack attached the following image(s):
hi roy, have you got some more of those decals?
roymattblack wrote:PM sent... thanks roy, looking forward to them arriving.
The decals and the wiring really make a difference Roy  W,T,G  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Moving ahead a bit now.. Another wheel sorted and fitted. Looking forward to the interior parts to come. Roy. roymattblack attached the following image(s):
Some quality work you’ve done there Roy. Can’t wait to see more Regards Gray
 Rank: Pro     Groups: Registered
Great Stuff, look forward to seeing more pics of the build. Rich.
Coming along nicely Roy Al
Love those extra details. Malc.
I've got the floor parts and I see there's a carpet pattern embossed into the plastic which indicates there will be no actual carpets supplied. Answer...? I made my own using paper patterns which took an age to make. I chose a 'biscuit' colour for the carpets as it's a colour Jaguar actually used on green E Types, and it goes well with my own light tan seats. I'm quite chuffed with the result. roymattblack attached the following image(s):
Nice work Roy  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
You should be chuffed with the result Roy, looks fab.... Regards Alan
A nice colour contrast between carpet and seats Roy  nicely done. Al
Joined: 05/05/2014 Posts: 230 Points: 657 Location: Northeast USA
No carpets-for such an expensive subscription this is disappointing; I'll have to go the route you chose and make patterns for carpeting as well I guess. Roy, will you be offering any of those wonderful seats for sale ever again?
Many thanks for the kind words you chaps. Any questions, PM me...
Looking forward to doing more on the interior.
Roy.
