35 Pages «<1213141516>»
Laszlo For's Diary Options
#261 Posted : 27 February 2018 06:28:57
Hi Laszlo,
Looking good, I'm sure all your efforts with the masking will pay off.
#262 Posted : 27 February 2018 08:42:42
Don`t forget to add another coat of black along the masking tape to seal it before adding the copper paint.
Otherwise the copper will flow under the maskin tape.
gingerale75
#263 Posted : 27 February 2018 21:50:20
Hello Walter,
Thanks for the advise, I haven't thought about this idea, but now I applied a thin coat of black.
Happy building!
Laszlo
gingerale75
#264 Posted : 27 February 2018 22:03:47
While waiting for drying the extra coat of black as advised by Walter, I started to prepare the copper paint.
And oh dear... I found two of my four pots being "dead". Blink
I think two pots are coming from the full paint set which was available to buy from DeAgostini shop, especially for this kit. The other two pots were supplied for two of the magazine issues, I guess around Issue 60-65.
When I was stirring the pots I found that two of them has blueish coloured big chunks in it and also its colour doesn't look a nice shiny copper. (See pictures below)
These chunks don't seem to dissolve even after 10 minutes of stirring.
The other two pots looks OK.
I also noted that even if the type number of the paints are the same (AP9126W) they have slightly different label.
In the picture the two on the left are the good ones, the two on the right are the "dead" ones.
Anyhow... I hope that the two pots will be enough to paint the hull with double coating.
Happy building!
Laszlo
gingerale75
#265 Posted : 28 February 2018 00:00:10
OK... So... Bravely I took a deep breath and started to paint the hull with copper.
Using fine flat brush around the rudder and wide flat brush anywhere else I applied the first coat of copper paint.
Eeehhh.... not quite happy with the result Crying
But as far as I remember from my modelling experience on plastic kits from 20 years ago, the first coat of these metallic paints always look ugly...
Also the paint didn't really want to stick on the areas where I filled the hull with milliput. At least not the first layer. Blink
Anyhow, I'm still positive, we’ll see tomorrow when second layer will be applied that will it look better.
Also on the bright side, referring to my previous post, for the first layer I used only half of the first pot, so still 1.5 pot left for the second, maybe third layer. BigGrin
Happy building!
Laszlo
#266 Posted : 28 February 2018 00:03:39
Looking well Laszlo doing a great job. coming along very well.
#267 Posted : 28 February 2018 07:57:13
Nice start to the painting!
#268 Posted : 28 February 2018 08:59:47
BigGrin Nice start on the hull paintingCool
gingerale75
#269 Posted : 28 February 2018 18:40:16
Second coat of copper paint applied.
The overall impression is much better now, however I'm still not 100% satisfied. Blink
The black paint still shading through around the masking tape...
Looks like that the copper paint doesn't stick well to the black paint. Let's hope that the third coat will cover it finally.
Luckily I got a bit left in the first pot, while the second pot still full. Cool
My main worry is the areas where gaps filled with milliput. Crying
The cooper paint doesn't stick at all... even the first layer came off when the second one applied. Cursing
Have you got any suggestions?
Happy building!
Laszlo
gingerale75
#270 Posted : 02 March 2018 23:30:40
Third layer of copper paint applied.
Overall it looks good but with the brush I still couldn't create a uniform shading.
I still got one critical milliput filled area which looks worse and worse with each layer.
The next layer removed the previously dried layer(s). after the third layer I anded up with a nearly white patch.
I applied another, fairly thick coat on this area to get the white area disappear.
Unfortunately it still has a noticeable shade difference.
On the positive note, this side won't be visible when displayed.
I won't apply a fourth layer, I believe it won't make the overall look better and might make the milliput area even worse.
Happy building!
Laszlo
travoski
#271 Posted : 03 March 2018 05:12:09
Hi Laszlo
The copper paint looks good I hope mine will turn out as good I also only have the two pots that came with the kit and it's not possible for me to get more I have not opend mine to check the condition yet though.I know it's a bit late but there is a product artists use to prime difficult surfaces it's call "Gesso"not sure if this would have helped though
Trevor
If my ship's going down,I'm bloody well getting off
#272 Posted : 03 March 2018 10:11:04
Nice job if the copper paint. In many ways painting the hull is harder than adding copper tiles as the paint will show every defect, you should be rightly proud if that finish
#273 Posted : 03 March 2018 10:22:41
Very neat job, the copper hull looks great.
gingerale75
#274 Posted : 06 March 2018 23:45:53
After few days laziness I carried on working. BigGrin
First, I painted the hinges black... this was a bit of pain due to my usual problem.
The paint didn't want to stick on the brass parts, not even with primer.
Anyhow, still managed to do it. Cool
And there came the drum roll.... removing the masking tape from the waterline.
HUGE SUCCESS... no bleeding at all, the worst thing was that the masking tape itself removed the black paint in few spots.
That was easily corrected with fine brush, also some correction was required where the waterline steps from the hull to the lower whale, but it wasn't difficult at all.
I'm very pleased with the result, the "bend" on the waterline (see my previous posts) can't be noticed at all.
Cool Flapper BigGrin
Happy building!
Laszlo
gingerale75
#275 Posted : 08 March 2018 01:05:18
As now the bottom of the hull finished I carried on working on the top half.
Issue 74
- Channel moulding added
- Holes of the previously removed pins filled with wood filler all around the hull, get it ready for the upcoming painting
Happy building!
Laszlo
#276 Posted : 08 March 2018 07:49:44
That looks very neat!
gingerale75
#277 Posted : 12 March 2018 00:12:28
Issue 74
- Entry port side parts filed to get them to fit to the hull and to the top part
- Entry port parts and the wriggles sticked to a double sided tape
- Primer spray applied to the parts using a leftover cardboard box as a paint booth to protect the dining table Cool LOL
Happy building!
Laszlo
gingerale75
#278 Posted : 12 March 2018 22:33:05
Issue 74 continued...
As the primer dried on the parts, first I made a little jig for the wriggles.
This is to ensure that all 26 is located at the exact same position (relative to the gun port), also make the fitting quicker. I used superglue to fix the die-cast parts and I wanted to avoid that it bonds quicker than I positioned the wriggles correctly.
- Once the jig is made all 26 wriggles fitted
- entry port parts painted black, left to dry till tomorrow.
Happy building!
Laszlo
#279 Posted : 13 March 2018 00:01:08
Coming along very nicely....Cool Cool
#280 Posted : 13 March 2018 08:57:01
Looking excellent, very neat work.BigGrin
Guest (12)
This page was generated in 0.474 seconds.
