 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 15/03/2017 Posts: 91 Points: 276 Location: Worcester, UK
Build the Jaguar E-Type, Stage 41Parts with Issue 41Tyre washer Take the Tyre and place it in boiling water for a few minutes to soften. remove it from the water and dry thoroughly. before the rubber cools push the rim of the wheel into the Tyre and stretch it around the whole wheel. It will take some force. Take the subframe assembly and align the lugs on the back of the hub with the notches on the right front axle. Take the washer and place it into the hub so the holes align and secure it with a single screw. Make sure the wheel spins freely (Picture 2) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Built: Deagostini Millennium Falcon
And that finishes another month. The wheel this time wasn't as difficult, Probably because i had done one before. I managed to go the 3 spoke method and i got the outer spokes right this time. the next issues will be good as it looks like we are getting the rest of the floor assembly. Its going to get bigger faster now!! Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Great work Ian  coming along nicely. Al
Another month and another set of parts Build the Jaguar E-Type, Stage 42Parts with issue 42Front floor assembly This issue contains the front half of the floor. Nothing is done with it in this issue Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, Stage 43Parts with issue 43Rear floor assembly Take the 2 floor panels and fit them together lining up the screw holes. Secure the panels together with 4 screws (picture 2) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, Stage 44Parts with Issue 44Lower casing Upper casing Right hand rear brake Left hand rear brake Right hand universal Joint Left hand universal joint Bonnet catch plate Take the brake and the universal joint marked with an L and fit them together. Repeat with the parts marked R. (Picture 2) Secure the assemblies to the lower casing with a single screw each. (picture 3) Fit the upper half of the casing to the assembly and secure with a single screw. (picture 4) Take the bonnet catch and position it into the hole in the front subframe. Secure from behind with a single screw (picture 5) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, Stage 45Parts with issue 45Rear Subframe Handbrake Linkage Take the drive assembly from stage 44 and position it into the rear subframe. Secure from below with 2 screws. (picture 2) next take the handbrake linkage and align it with the assembly. Push the pin into the hole and position the two arms over the holes in the subframe. secure the linkage with a screw through each arm. (picture 3) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
looking good Ian  nicely done. Al
Looking very nice Malc.
 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
looking good ian.  keep up the good work.
Nice work Ian  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Looking good Ian Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
coming along very nicely Ian. Mark Regards Markwarren (Mark) Admin
New month, new parts YAY!! Build the Jaguar E-Type. stage 46Parts with Issue 46Shock Absorber bodies Shock Absorber pistons x2 Coil Springs x2 Hub Carrier Left-hand wishbone Left-hand halfshaft Universal Joint Mounting plate Long spindle Medium Spindle Short Spindle x3 Take the shock absorber bodies, coil springs and pistons. Slot a spring over one of the cylinders on the shock absorber body. Fit one of the pistons onto the top of the spring and secure it by fitting a screw into the end of the piston shaft. repeat for the second shock absorber (picture 2) Take the assembly and secure it to the subframe assembly with the mounting plate (picture 3) Take the half shaft and universal joint. Fit the joint into the end of the half shaft without the lug. Push and secure the joint to the shaft with a short spindle. Fit the fork over the universal joint and secure with another short spindle (picture 4) Take the wishbone and taking note of the alignment. Ease the 2 eyes from the shock absorber over the pins on the wishbone and align with the holes in the subframe. secure the shock absorber eyes with screws on each side. Take the last short spindle and push it through the shorter of the 2 holes on the wish bone. Secure the opposite side with the medium spindle. (picture 5) hake the hub carrier and position it over the universal joint. secure it to the wishbone with the long spindle (picture 6) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, Stage 47Parts with issue 47Shock Absorber bodies Shock Absorber pistons x2 Coil Springs x2 Hub Carrier Right-hand wishbone Right-hand halfshaft Universal Joint Mounting plate Long spindle Medium Spindle Short Spindle x3 This is basically identical to issue 46 Take the shock absorber bodies, coil springs and pistons. Slot a spring over one of the cylinders on the shock absorber body. Fit one of the pistons onto the top of the spring and secure it by fitting a screw into the end of the piston shaft. repeat for the second shock absorber (picture 2) Take the assembly and secure it to the subframe assembly with the mounting plate (picture 3) Take the half shaft and universal joint. Fit the joint into the end of the half shaft without the lug. Push and secure the joint to the shaft with a short spindle. Fit the fork over the universal joint and secure with another short spindle. Take the wishbone and taking note of the alignment. Ease the 2 eyes from the shock absorber over the pins on the wishbone and align with the holes in the subframe. secure the shock absorber eyes with screws on each side. Take the last short spindle and push it through the shorter of the 2 holes on the wish bone. Secure the opposite side with the medium spindle. (picture 4) hake the hub carrier and position it over the universal joint. secure it to the wishbone with the long spindle (picture 5) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, Stage 48Parts with issue 48Rear anti-roll bar Bracing plate Right-hand radius arm Left-hand radius arm Mounting brackets x2 Safety straps x2 links x2 Take the anti roll bar and fit the links over the lugs at the ends of the bar. Fit the 2 radius arms onto the other ends of the links (picture 2) Lay the assembly onto the underside of the floor assembly. Fix it to the floor assembly with the 2 mounting brackets. (picture 3) Flip the radius arms over and position them over the holes on the floor. Secure the radius arms to the floor with the safety straps as shown (picture 4) Take the subframe assembly and fit it into the car floor assembly aligning the holes in the wishbone with the lugs on the radius arms. Secure the subframe with 4 screws (picture 5) Fit the bracing plate to the subframe and secure with 2 screws (picture 6) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, Stage 49Parts with issue 49Silencer upper half Silencer lower half Take the 2 halves of the silencer and fit together securing with 4 screws (picture 2) position the silencer onto the underside of the floor matching the posts with the holes. Secure with 2 screws (picture 3) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Another month down and its really looking good now. Next month it looks like another wheel (cry) Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Hi guys, I got this months issues and have built the wheel, I won’t be posting a build diary for them as I have already done that for 2 wheels. If your interested feel free to go back and look at issues 39 - 41. It’s really starting to come together now and as soon as the wheels are done and we can start properly building body it’s going to look amazing Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Looking good Ian and looks like you are really enjoying this build. Well done so far. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
