17 Pages «<910111213>»
benny's build Options
benny
#201 Posted : 03 June 2011 23:07:19
the next deck is finished and stained
cheers benny
benny
#202 Posted : 03 June 2011 23:21:49
MY PICS AV GON BIG??
cheers benny
benny
#203 Posted : 03 June 2011 23:24:47
now there small it must be photobucket
cheers benny
jeff averre
#204 Posted : 05 June 2011 18:33:39
Verry good looking deck there Benny, nice and even, good colour.
Excelent work mate.
(and that's not an advert for a 'Black & Decker' work bench!!LOL
Jeff
tom.ganc
#205 Posted : 05 June 2011 21:57:49
Great stuff mate. I like colour of your deck. Very nice.
#206 Posted : 13 September 2011 22:00:53
Good stuff BennyBigGrin Cool deck colour is very nice
benny
#207 Posted : 13 September 2011 22:02:46
hi mwg thanks but am having trouble with pic size so i deleted ..watch this space
cheers benny
benny
#208 Posted : 13 September 2011 22:08:20
hi all not been about for a while what with holidays and work so i will hopfully start where i left off ..i replaced the horrible pins and string around the stairwells with a wooden handrail..in all these pics the painting and varnishing is not finished
cheers benny
benny
#209 Posted : 13 September 2011 22:11:07
next pics are the cabins and wheel ..i replaced the wheel supports with a peice of 3x3 it looks more solid to me
cheers benny
benny
#210 Posted : 13 September 2011 22:18:23
next was the lining of the top layer of gunports and painting of the upper deck walls
cheers benny
benny
#211 Posted : 13 September 2011 22:26:48
i have been doing the main mast this week ..very tricky but enjoyable
cheers benny
#212 Posted : 13 September 2011 22:39:17
Hate to tell you, but your topgallant mast holes appear to have been drilled on the wrong side of the mast.
The dotted lines on the plan represent holes that run forward to aft, it is only the bottom pair of holes that run port to starboard.
For the top six holes, the mast was to be rotated thru 90 degrees, I seem to recall SoB and one or two others making the same mistake which is easy to overlook during the haste of build.
benny
#213 Posted : 13 September 2011 22:47:44
thanks tomick i will look into it much appreciated .. is there anything positive to say to a beginnerConfused thanks anyway
cheers benny
#214 Posted : 13 September 2011 23:16:14
You've ploughed on very well, and it seems to be taking shape nicely and the peronal touches making it your own.
For a novice builder you've done very well, simply because a model ship of this level is not an easy build by any standard, but the magazine certainly makes it possible and far easier than the build manual in the standard kit, which is formatted in the knowledge that you know or have a good idea as what needs to be achived and how to go about it.
Keep up the good work! Cool
Son of Bulwark
#215 Posted : 14 September 2011 09:54:24
Hi benny! Cool
Glad to see your build again mate! you have been away for a while doing other things. I look forward to seeing more soon.
It is easy to overlook this problem as there is no mention of it on the plans.
#216 Posted : 14 September 2011 10:16:29
But there is clear note of the process in the instructions
farrabass
#217 Posted : 14 September 2011 14:34:51
SOME-ONES BEEN BUSY.
You have done a lot since your last post, the holes for the the mast are simple to fix. Cocktail sticks are so useful for filling misdrilled holes, I have had to use them to fill in some misdrilled holes in the main fighting top.
As Tomick has pointed out the instructions are quite clear, but, if the reader doesn't interpret the instruction as the writer intended mistakes will happen. That is the benefit of this forum, Tomicks excellent step by step guide and some very good build diaries posts by other members.
Not forgetting the usually very good build instructions with the magazine, But all in all your build is coming along very well, and I can see by your posts that you are for the most part enjoying the build!
Keep up the good work, I look forward to your next post.
Steve..
benny
#218 Posted : 14 September 2011 22:13:03
cheers guys
cheers benny
Tiswas
#219 Posted : 16 September 2011 18:55:57
I agree with all that has been said before, a nice clean build with some extra personal touches. Well done Benny.
TIS
benny
#220 Posted : 16 September 2011 19:55:55
thanks tis i have repainted the main mast as how it is now and not per instructions,will be posting pics tomorrow
cheers benny
