6 Pages «<3456>
IJN Mikasa 1902 by Jase Options
#81 Posted : 21 February 2018 22:28:05
Thank you both for looking in and your comments
wait until you see the funnel etch Drool Drool Drool Drool
#82 Posted : 24 February 2018 23:52:04
Lower superstructure part 1
With the first set of winches done my next task was the lower superstructure amidships.
first up is a smal structure to which a single door and some hatches are added from the upgrade set. Photo 1.
The etch doors are made u of 3 sections which are folded to create an outer and inter surface as well as a door frame. this allows toy to model any door open if your wish. Photo 2 &3.
The second small structure has the kit supplied boat support replaced by etch. Photo 4 & 5
The next structure will accommodate one of the funnels. there are etch doors to add as well as a hatch
The last structure is more complex in terms of the etch. this part has some kit supplied etch, some mesh that sits in the top. the upgrade etch has folds to the side which lift the grill making it much more realistic. 6 hatches are also added, these fold in the same ways as the doors. finally two replacement etch boat supports are added.
All the parts were primed with Halfords grey before bing painted with light grey. Although the artwork depicts the ship with white upper works this is not correct. it was a pail grey, IJN greys all appeared to dark so after trying several I settled on this grey.
Once dried the parts were secured in place with CA.
#83 Posted : 08 March 2018 21:07:15
Deck fittings part 1
I started the deck fittings at the bow. there are a number of parts to be fitted that need no alteration, but most the hatches have some form of etch part to be added.
The kit comes with anchor grills the ones in the MK1 set look much better however.
Most the hatches can be displayed open. some kit parts are totally replaced by etch.
I decided to display one hatch open so added a little wire to depict it proper open
the 6 etch parts that are attached to a hub are kit parts, not sure what it is though?
the wood deck needed a little trimming to take some part correctly
there are some very small etch discs that go on the deck. both the kit and the MK1 set supply these the MK1 set had a little more definition so I used them
#84 Posted : 08 March 2018 21:17:19
Hi just caught up on this build looks great.cheers Mick.Blink
#85 Posted : 09 March 2018 08:52:26
Mthanks Mick for looking in and your comments
#86 Posted : 09 March 2018 12:41:57
Nice detail being added, well done Cool
#87 Posted : 11 March 2018 08:45:56
Thanks for looking in Mr T, its a very enjoyable build Cool BigGrin
#88 Posted : 11 March 2018 09:14:47
Air vents Part 1
one of the loverly features of this kit is the large number of air vents. By 1905 most of the upper cowls had been removed and this kit comes with the etch to work the later vents, as does the MK1 set. however as launched in 1902 all the vents had cowls
Both the Kit and the MK1 set have cowl grills. My research has not been able to identify which is most accurate, however I decided I prefer the look of the kit grills which sit inside the towel rather than the MK1 which cover the whole from as this would be visible.
some considerable care is needed to check the orientation of the cowls the instructions are good but once they are built and painted it is very easy to mix them up
there is some cleanup and filling required at the base of a small number of the vents but otherwise fit is really nice.
#89 Posted : 11 March 2018 10:27:49
That’s looking really nice, great work.Love
#90 Posted : 12 March 2018 22:27:08
Thanks Mark, small plus on this now for the V2 build then back on it.
#91 Posted : 12 March 2018 23:49:35
Good to see the progress you're making with this one, nice work....Cool Cool
Halwende
#92 Posted : 13 March 2018 10:56:03
Rank: Newbie
Wow fantastic work;
#93 Posted : 13 March 2018 13:21:46
Thanks both BigGrin
Halwende welcome to the forum Cool
kpnuts
#94 Posted : 13 March 2018 17:29:10
All that pe gives me the colly wobbles looks great though
Halwende
#95 Posted : 13 March 2018 21:26:35
Rank: Newbie
TY jase; I joined this forum because of your Mikasa build; I always wanted to build this Battleship but felt it was a bit out of my depth; you my friend are turning that all around and I have now have the model and the Pontos detail up set; and I am following your build as a guide;I am retired and haven't built anything in 30 odd years; but this year have started Modelling again; built a few tanks and they turned out OK; so the next move is into a 1/200 scale ship; and here we are today; I love your work and I love the way you set it out for the build; BTW the only reason I chose the Pontos kit is that it provides a set of jigs for the holes for the etch ladders; I thought it would make life easier for my failing eyes (I'm 66 this year)anyway Jase love your work;am enjoying your build very much; and am looking forward to starting mine soon; later mate
#96 Posted : 13 March 2018 21:35:02
Excellent work as always Jase, I'm not a ship modeller especially period ships, as I keep saying but I do enjoy watching some of the more modern metal hulled warship builds on here and yours is one of the more fascinating for me.
Keep up the good work mate and well done again. Cool ThumpUp
#97 Posted : 14 March 2018 07:43:56
Well you have certainly bought into a very nice kit. the points set is loverly but very advanced so go steady with it. if you need anything just give me a shout.
Are you doing the 1905 version?, would be nice to see another of these on the forum Cool hope you share your build.
with you on the eye I get my first set of glasses next week, I could be looking at this next week and be shocked at the state of it Laugh LOL LOL LOL
Ill post more soon
#98 Posted : 14 March 2018 07:48:26
thanks Alan, ken Kev.
the etch gives me the collywobbles tooLOL LOL
thanks for taking the time to post a comment
@kev I get that totally I have no real intrest in cars but there are some great builds I follow. although I love all ships generally I do like the more Industrial Age of sea, ocean steamers etc. makes is very industrial looking, so is the Titanic I will start later this year, and wait and see what I am building for my 50th Birthday in a couple of years time Drool Drool Drool Drool Drool Drool Drool Drool Drool Drool Drool Drool Drool Drool Drool
#99 Posted : 14 March 2018 09:19:57
Wow - this looks great! Excellent work!
Halwende
#100 Posted : 15 March 2018 21:42:22
Rank: Newbie
Once again jase TY for your support; and yes the kit is a beauty although the pontos set is a bit gobsmacking! have found a workaround for my sight problems have purchased a magnifying glasses set with 4 different lenses so that works for me!; also my partner got me a work bench light with a magnifying lense; so its all good: As for the build; 1902 as built but before 1905; I want that Predreadnought feel and you get that with the Black Hull and light upper works; after Her first refit she lost all that and she became just another grey Warship; as for sharing..........as of now don't know how to upload stuff- but learning; nuff said;TY for your great build and I look forward me the next bit. Hal
6 Pages «<3456>
This page was generated in 0.285 seconds.
