38 Pages «<7891011>»
Garth's Black Pearl Options
#161 Posted : 22 January 2018 08:34:51
Hi All,
Back to some actual modeling again. I'm glad to be done with the fiddly bits.
I found it easier planking the second deck off the job. I kept it in two halves, running down the centre line if the ship. I measured the coffee stirrer and halved the dimension and drew a line along the deck. My intension is that the coffee stirrer will overlap the other half of the deck part hiding the seam.
Before a started the planking, I taped the decks together and made sure that they fitted comfortably.
I laid the centre plank first taking care of its position. Once it dried I laid the remaining planks. I planked over the smaller openings and will cut them out once dry.
A couple more test fits as I approached the slots for the bulkheads and eventually everything fitted snugly.
Once the coffee stirrers were dry, I flipped the deck and scribed some lines on the underside. This will resemble the underside of the deck. I’m not sure how much will be visible though.
kind regards,
garth
#162 Posted : 22 January 2018 10:00:10
Very neat and tidy work as usual Garth, all looking good.... Cool Cool
Gibbo
#163 Posted : 22 January 2018 14:43:03
There's some great little bits going into this, love the lighting, love the skeletons.
Paul
#164 Posted : 02 February 2018 06:23:01
Hi Alan & Paul,
Thanks for looking in and for the inspiration.
#165 Posted : 12 February 2018 10:02:37
Hi All,
I Stained deck using Light Oak wood stain. I like the alcohol-based stains as they dry pretty fast.
Once all was dry, I fitted the deck to the ribs. Fortunately, the deck has been in and out a couple of times and is a fairly loos fit. This is important, should the components be forced, they may move some parts out of alignment and end up with a warped model.Cursing
#166 Posted : 13 February 2018 13:17:49
Hi Garth.
decking looks really good. love the colour.
Ian Cool BigGrin
#167 Posted : 15 February 2018 14:25:55
Hi Ian,
Thanks for looking in and for the kind words.
#168 Posted : 16 February 2018 08:59:16
Hi All,
Started Starboard side panels. I fitted the external panels as per the instructions, but the internal panels are devoid of any detail.
Following an old Pearl blog, (Thank you Swordfish Fairey) I liked the offset between the black and Light oak colour of the internal wall sections.
To achieve this, I scored lines to represent planking, darkened them using a B4 pencil & stained using Light Oak wood stain. Coffee stirrers to the rescue again. I painted them and some left-over Victory planking black to resemble the internal structure and glued them to the scored piece.
#169 Posted : 16 February 2018 12:11:52
Hi Garth,
Read your post today. When you mentioned 'coffee stirer' i was so intrigued that i read your whole build diary! What a great idea, and loving your build, and colour of your deck.
Keep up the good work.
Gray
#170 Posted : 16 February 2018 14:36:50
Looks great Garth, doing a great job.
Chris Cool
#171 Posted : 16 February 2018 15:45:17
Really coming along great Garth BigGrin regards PhilCool
#172 Posted : 16 February 2018 23:45:00
Nicely done Garth and some nice tips too.....Cool Cool
travoski
#173 Posted : 17 February 2018 08:20:07
Hi Garth
Great build so far wow if only I had a little of your skills waiting for the next update
Trevor
If my ship's going down,I'm bloody well getting off
#174 Posted : 17 February 2018 08:51:49
Just caught up with your build, looking great. Love the decking colour.ThumpUp
#175 Posted : 19 February 2018 10:35:30
Hi Guys,
Thanks for looking in and once again for the kind words.
#176 Posted : 23 February 2018 13:48:44
Hi All,
Fitted the Port side panels. Applied the same treatment as with the Starboard side panels.
I have a commercial nailer, but it never seems to hold the pin properly. To rectify this, I made this nailer after I completed my Victory planking. The pliers just seem to give so much more control.
I have posted these pics in my HMS Victory build blog, but I will post them again here.
I cut a slot into both jaws of an old pair of long nose pliers to accommodate the pin head and filed a grove down the middle. No more twisting/rotating pins!!! BigGrin
Since posting that, I have learned that model railroad suppliers sell the exact pliers - with slots milled in for pinning model railroad tracks.
#177 Posted : 24 February 2018 00:22:36
Lovely work Garth, do like your build methods..... Look forward to seeing more of your work.....Cool Cool
travoski
#178 Posted : 24 February 2018 04:44:58
Garth wrote:
Hi All,
Nothing wrong with a few ice cold Windhoek Draughts while you build either
Trevor
#179 Posted : 24 February 2018 12:05:25
Great work Garth, loving the attension to detail.
Gibbo
#180 Posted : 24 February 2018 12:34:23
Very nice Garth, looking forward to seeing more
Paul
Guest (5)
