WEIGHT OF CAR ? Options
Skiddy
#1 Posted : 30 May 2011 22:43:51
I'm assuming this car is going to be quite heavy when finished as the wheels are fairly weighty on their own.
Anyone know ?
Austin
#2 Posted : 01 June 2011 01:16:29
Well I hope there are many more metal parts, I think when a model has weight it really gives it an added detail, more of a realistic stance.
dave1978
#3 Posted : 01 June 2011 09:28:31
Yeah 75kg to scale would be nice ;-)
Austin
#4 Posted : 01 June 2011 19:39:06
Not sure about 75kg dave1978, would need some reinforcing to do on the shelving. 10kg would be fine.
Skiddy
#5 Posted : 02 June 2011 18:53:55
In a realistic world I would expect approx 1KG ish Unsure
HansBlack
#6 Posted : 02 June 2011 19:48:47
about the same as a bag of Sugar, I would hope so lol 10 KG? I would need a reinforced Shelf
Dontshootme
#7 Posted : 26 June 2011 11:00:41
Roger,may I advise that you change your user name m8,it's never a good idea to have your email address on public view...there are those that see it as an open invitation to send all sorts of nasties to you!
Jake da Jeweller
#8 Posted : 26 June 2011 11:58:27
One Front tyre and one front hub weighs 5.1ozs Flapper Not that is of any use to anyone!!
Forgive me for I am old and cannot measure in kilopedes or centrewatts
Drams and cubbits are my thing
Mishkin
#9 Posted : 30 June 2011 10:04:50
The total weight of the James Bond DB5 Aston Martin is 8.4kg. That model has a metal body so I would be surprised if the McLaren is heavier.
Skiddy
#10 Posted : 14 July 2011 12:39:39
Guess my estimate of 1kg is out, the two front wheels fully made up on wishbones weigh 420 g...without the calipers btw Unsure
Austin
#11 Posted : 14 July 2011 18:12:00
My guess would be around the 4kg mark.
jameelassan
#12 Posted : 03 October 2011 15:32:31
guys for 1:8 model is hmmm a weight of a f1 car is around 140kg divide it to 8 and mabye its a around 17.5kg guys
S2ksean
#13 Posted : 03 October 2011 16:20:18
Mr t/admin do u have any idea the answer to this question? Approx would be fine.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
scottww86
#14 Posted : 03 October 2011 16:23:54
minimum permissible weight for an F1 car in 2008 was 620Kg if i remember rightly!
jameelassan
#15 Posted : 03 October 2011 16:35:18
are u sure a formula 1 cars are lighty build Confused
http://www.rsportscars.c...s-mp4-23-formula-1-car/
its 600kg hamilton is 55kg so its 555kg minus the camera mabye 500kg+ so hmmm not sure lol f1 cars are now 140kg if i am very very sure
#16 Posted : 03 October 2011 17:13:34
Nice photos thoughCool BigGrin
meffman
#17 Posted : 03 October 2011 23:43:47
Evening All, the weight of formula one cars for the 2008 season was reduced from 605kg to 550kg, current weight for this season is 650kg so if you do divide 550kg by 8 approximate weight would be 68.75kg which if i'm not very much mistaken is erm very heavy indeed!!
MeffMan BigGrin
Dontshootme
#18 Posted : 04 October 2011 08:47:02
Don't think you will find weight follows the same rules
ie @ 1:2 scale everything is half size..but not the weight..or at least I hope not as we Victory modellers are going to end up with nearly 4 feet of model weighing several tons sitting on a shelf or cupboard!!!!!!!!!!Blink Blink Blink
jameelassan
#19 Posted : 04 October 2011 09:20:18
ohhhhh now i found wats 140kg its the engine xD
Smeg and the Heads
#20 Posted : 04 October 2011 09:51:05
Hi Guys
Thes scale weight of the McLaren is a little over 1kg.
Dontshootme is right the 1:8 applies to the measurments but not weight, volume etc. so to work out the scale weight you have to divide the weight of the real car by 8cubedConfused(8x8x8=512)or to put it another way you need 512 1/8 models to fill the same volume of a full size original. So if we assume jameelassan has gone round to Lewis's house with some scales and he does indeed weigh 55kgLOL and the weight of the car is 545kg (600kg = car + driver) then the scale weight of our model is 545/512=1.064kg.BigGrin
I know what you are all thinking, how can 1/8th go into 512Confused. Imagine you have a big room and lots of models, if you put the models on the floor to create a grid of 8 models long and 8 models wide you will have 64 models on the floor, you will then need 7 more layers like this to acheive the height 8x64=512.
Still confused? so am ILaugh
