Good to see thIs Build of the Year 2018 entry underway, looking forward to seeing how it turns out
 Nice start Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 07/07/2015 Posts: 1,292 Points: 3,928 Location: Allentown PA
Thanks guys, starting to roll along now. Stage 4 is done just got to get photos finished and post it up. Month two and three are supposed to ship tomorrow. Fingers crossed on that. DeAgostini kit builds:
Millennium Falcon: 18% Complete Shelby GT-500: 28% Complete Thunderbird 2: 13.75% Complete
Now for Stage 4. Real simple stuff. Panel lined the lower half of the front fuselage. Removed the “2” graphic from the open panel. Panel lined that as well. Painted the edges red for the intake. Assembled the lower hatch/bay area, and places the observation window in place. There are more parts for the Thunderbird 4. Since I am not using it they were bagged up with the others. Metal Mech attached the following image(s): DeAgostini kit builds:
Joined: 12/01/2017 Posts: 572 Points: 1,731 Location: Cambridgeshire
As an example of a TB2, that is clearly a FAB 1! [I'll get me hat.] Current Builds Eaglemoss: Ecto-1, BTTF Delorean [Installing Mods] Hachette: T800 Endoskeleton Agora Models Shelby Cobra 427 [Plate 031] BanDai 1:5000 Imperial Star Destroyer AMT 1991 U.S.S. Enterprise Bridge [Installing Mods & Lights]
Finished Builds Deagostini: R2-D2 [Never getting batteries]
 Rank: Amateur Level 1   Groups: Registered
Joined: 14/11/2017 Posts: 31 Points: 96 Location: USA
Why did you remove the badging?
OTSW77 wrote:Why did you remove the badging? I am not actually building the “Thunderbird 2” from the tv show. I am building a “mech dropship”. It will have its own custom badging. DeAgostini kit builds:
I guess it's something like the Dropship and APC in Aliens?
Are you going off of some reference pics
Nope, it’s from my own imagination. DeAgostini kit builds:
Ok I received month two now. Now that I have the bottom half of the main body I was able to get a good idea of space available for my plans. Had to rethink and change up my original plan but I think I got a good idea how to work it. I still have other plans for the pods, but I need month three so I can see if those plans will work. For now here is Stage 5. Installed the interior compartments for the observation windows. Assembled the test box and tested the lighting in the cockpit. Metal Mech attached the following image(s): DeAgostini kit builds:
Stage 6. Panel lined the rear cockpit trim. Painted the edging red on the trim around the vent area. I also want to paint the edging of the yellow stripe but don’t have the yellow paint right now so will do it a bit later. Then finally attached the trim to the main part of the cockpit. I will not be using the rescue vehicle for from this stage. So the parts were bagged up and set aside. Metal Mech attached the following image(s): DeAgostini kit builds:
 Rank: Pro     Groups: Registered
Looking very nice. love the lighting. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Great work. Looks great.
Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Metal Mech, please clear your PM's. Thanks for the info btw.
Coming along nicely, look forward to seeing more.
pemberg wrote:Coming along nicely, look forward to seeing more.
Graeme Got more coming up shortly. I had to wait till I got some supplies from a Gundam store and I been doing some test building to see which direction I head in. So look for a updated post soon. DeAgostini kit builds:
Time for Stage 7. This is a simple one. First off I finally got my yellow paint in. So first I painted the edges yellow. Next up I install the left and right vent. I won’t be building the Recovery Vehicle so the parts were bagged up for later. Metal Mech attached the following image(s): DeAgostini kit builds:
Coming on very nicely. Mark Regards Markwarren (Mark) Admin
Guest (6)
