 Hi does any one know where the Small thin black wire goes to on the Header Tank just above the Radiator cheers Gold Finger
Joined: 05/05/2014 Posts: 230 Points: 657 Location: Northeast USA
I believe it's the overflow line, it runs down the side of the radiator
 Thank you eagle cheers mate Gold finger
Hi Goldfinger, please can you not title every query post the same, the title should be specific to content.
Thanks
Spal wrote:Hi Goldfinger, please can you not title every query post the same, the title should be specific to content.
Thanks
Al i don't understand what you trying to say can you explain in Laments terms Gold Finger
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,195 Points: 15,734 Location: ipswich
I think he means to actually mention the question you want an answer to, and not just say 'E Type Jaguar'.
As the question is in the E Type section anyway, your query title doesn't actually mean anything and is confusing when you use it for all of your different questions.
Your previous 2 topics were both titled etype.jaguar which is a general heading and may not help you get the answers you require.If you were more precise in your choice of Topic heading for example: Header tank pipe, you may find you get answers quicker to any issues you have, hope that helps.
 Hi i get it and fully understand don't forget i am new to this Forum and you pick up things along the way which i now know how to title each query i need help with Auric
