Dome cleaning Options
kryten2b
#1 Posted : 07 February 2018 11:55:09
What is the dome made from & what can we safely use to clean fingerprints etc of the nice shiny surface without damaging it?Confused
Current Builds:
McLaren MP4-23Finished
Millennium Falcon
R2-D2
BTTF Delorean (Maybe)
#2 Posted : 07 February 2018 12:11:28
Any non-abrasive mild cleaning fluid such as those used on plastic surfaces should be fine but always do a test before using it.
PhilC
#3 Posted : 07 February 2018 14:05:09
Baby lotion is good for this
SOME MORNINGS IT JUST DOESN'T SEEM WORTH IT TO GNAW THROUGH THE LEATHER STRAPS
semaj
#4 Posted : 07 February 2018 23:17:58
its stainless steel, so anything safe for that will do the trick. keeping your hands clean before handling will help reduce the fingerprints
Building:
Complete:
#5 Posted : 07 February 2018 23:24:55
Yes its stainless steel but it also has a blue paint stripe that a stainless steel cleaner may take off. It may be a good idea to clean the dome and then give a clear-cote to protect the finish if you want a pristine finish if your weathering then who caresLOL LOL LOL
LSainsbury
#6 Posted : 14 February 2018 20:42:53
And don't push in the blue panels when cleaning! :-)
#7 Posted : 14 February 2018 21:02:51
BigGrin Should not be a problem once all the plastic allen keys are fitted to the domeCool
This page was generated in 0.104 seconds.
