 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 09/12/2014 Posts: 75 Points: 224 Location: Timaru, New Zealand
Hi all. Does anyone know the size of the nylon thread that was supplied with the Hood partwork? I’ve been using it for some other models and I’ve now run out of it. Is it 0.1mm? Any help would be great. I’m sure it said the size in the magazine but I can’t for the life of me find where I’ve put them! Cheers, Hilux On the Go RMS Titanic 1/250 (third time)
Completed RMS Titanic 1/250 (twice), DK Bismarck 1/200, RMS Queen Mary 2 1/400, HMS Hood 1/200
Hi. Having checked it comes in issue 136. It doesn't say the size but having measured it with caliper it's 1.7mm nylon - basically its fishing line. It would be cheaper too, to get some fishing line that size. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
1.7mm? It looks a lot thinner than that. Looks less than 1mm. I was guessing about .15mm. Ii was thinking fishing line would be the best option. Might go my local shop tomorrow. I’ll take what I have left in with me. Cheers magpie. On the Go RMS Titanic 1/250 (third time)
 Hi I have used black EZ Line for ages for most rigging on aircraft and ships it comes in two sizes and a link is provided below:- http://berkshirejunction...m/subdirectory/ez-line/
For flat rigging wire like on a 1st WW model I also use Prym knitting elastic it comes clear but will take a colour of your choice:- https://www.ebay.co.uk/i...c105:g:5-0AAOSwgQ9Vr~yi
Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Ah that’s perfect Andy. Thanks very much. Will order some of that. Cheers, Ryan On the Go RMS Titanic 1/250 (third time)
Titanic5972 wrote:1.7mm? It looks a lot thinner than that. Looks less than 1mm. I was guessing about .15mm. Ii was thinking fishing line would be the best option. Might go my local shop tomorrow. I’ll take what I have left in with me. Cheers magpie. Yeah your correct sorry decimal in wrong place .17mm is the size it says on calipers. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Haha great thanks Chris. On the Go RMS Titanic 1/250 (third time)
I use EZ too it keeps taught if ther is any mivment inthe part it is attched to which is very helpful “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
