Middel Deck beams Options
travoski
#1 Posted : 26 January 2018 10:18:02
Hi All
A little help if possible please I am busy fitting the Middel Deck side beams(not sure if thats the name) I have shaped them and cut the grooves so they can bend but I am not sure if they are supposed to "mate"with the rib in other words they would have to be at an angle or if thy should remain vertical and only make contact with the top of rib and the deck the video and the instruction pics do not have a close up view of this hope I am explaining what I mean correctly
If my ship's going down,I'm bloody well getting off
z8000783
#2 Posted : 26 January 2018 10:21:59
Groups: Unapproved
These are the dummy gun supports which will be drilled and the guns pushed in from the outside, so they need to remain vertical.
All of these will be covered up and the insides painted black and so any small gaps between the support and the rib, will not show.
#3 Posted : 26 January 2018 10:23:02
Can you let me know what issue number you are referring too and if you can post up some pics of your problem then that would also help.....
travoski
#4 Posted : 26 January 2018 10:49:18
Hi Alan
Thanx for reply the issue 19/20 the side support beams
travoski attached the following image(s):
travoski
#5 Posted : 26 January 2018 10:51:19
Thanx John
I have attached a pic in the next reply
#6 Posted : 26 January 2018 11:39:45
Hi Travoski,
Thanks for uploading a pic, its a great help. As has been said, the dummy gun supports should remain vertical, you can see this if you take a look at the Official Build diary. Here's a link...
https://forum.model-spac....aspx?g=posts&t=814
Hope this helps..
