2 Pages <12
Dome & frame alignment Options
#21 Posted : 23 January 2018 11:40:28
As you say, building something or kit bashing for your own purpose is okay. But, I think it is unfair to ask a third party for measurements, for you own purpose rather than obtaining them yourself. Simply by asking for this information, the third party in question could be in breach if copyright themselves as it is not for their own purpose, and it would still a form of plagiarism even if gained through a third party.
Coser
#22 Posted : 23 January 2018 13:50:00
Not quite true, Questor.
The parts are copyright, meaning that Deagostini own the right to copy them. Making copies for sale or for yourself, would still be illegal.
however, I understand what you are doing. you are making your own parts, to your own designs, to fit in their model as replacement parts.
It is classed as "Fan Activity" and there is a certain leeway normally granted in these cases. I mean, it would be rather low for a company to complain that to make the model you want, you are being forced to buy their £800+ kit.
Unfortunately, I am also not good enough to be able to give you the information you need due to the part being a hemisphere.
For example, take a sphere such as the Earth. start at the North pole, and travel directly South. Turn 90° left when you reach the equator, and travel along the equator for a 1/4 of its distance. Make another 90° left turn, and travel North the same distance you travelled South.
If you try and draw that on a flat piece of paper, you have walked un a 'U' shape, but on the globe, you've actually walked a triangle with three sides and three equal 90° angles.
Current Builds
Hachette: T800 Endoskeleton
Finished Builds
#23 Posted : 23 January 2018 14:08:56
Clearly the answer to this is to wait until you received the item in question then you can take your own measurements. I'd hate to hear of misunderstood dimensions being given and blame being laid if the "made" item does not then fit.
At that this topic is locked.
2 Pages <12
