Thanks Alan  these large scale cars are great but they do take up some space Al
you are right, they are really great scales to find their place
Coming along nicely, Al. Keep up the good work. Malc.
Thanks Malc Al
Pack 15 This pack is mainly adding parts to the engine and also some brake pipes and a couple of hoses. Thanks for looking. Al Spal attached the following image(s):
pack 16 Starting to add some of the larger sub assemblies to the monocoque. Have added the front brake ducts, ty-wraps on front and rear brake lines, the pop off valve, radiator housings, the injectors and fuel pipes. Thanks for looking Al File Attachment(s): Spal attached the following image(s):
Spal wrote:pack 16
Thanks for looking
Al buon natale spal
Thanks Maurizio  Merry Christmas. Al
Pack 17 In this pack both turbos are built and fuel pipes added followed by attaching the fuel pump and header tank hose to the engine block.The left and right wastegates are assembled and the oil/water heat exchanger has been attached to the engine block. The check valve and the water inlet pump pipe are added to the header tank and the throttle sensors and oil filter joints to the plenum chamber. Thanks for looking Al Spal attached the following image(s):
 Looking good Al Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks Andy Al
Pack 18 In this stage the header tank and plenum chamber are fitted, followed by the nosecone. After the fitting of the two intercooler to engine pipes the engine is temporarily fitted onto the rear of the monocoque by its mounting plates. Pipework is added to the turbocharger and wastegate assemblies before the underbody is fitted and the turbochargers then added. The rear underbody is then used to correctly position the exhaust pipes while the glue cures. Once this was done the turbo air intakes had pipes fitted and temporarily fitted in position. These were then removed as was both underbody panels and the engine block. Four hoses were then attached to the block and turbos. Thanks for looking Al Spal attached the following image(s):
Nice work Al, it does look impressive. Mark Regards Markwarren (Mark) Admin
This kit is on my wish list, and seeing your build is making me want it even more. Great work. Rich
Thanks for looking in guys  Its a great kit Rich treat yourself. Al
Pack 19 The penultimate set of parts has arrived.In this pack we assemble the seat harness and add the fuel filler neck before adding a couple of stickers to the steering wheel. This was followed by attaching the battery cable and several wires to the CDI unit,telemetry unit and electrical system. The final part of this pack was the fitting of various switches to the instrument panel followed by the data and rev counter display. Al Spal attached the following image(s):
That's looking great. Nearly complete!! Malc.
Lovely work Al, looking stunning. Mark Regards Markwarren (Mark) Admin
Nice work Al, looking good as you go into the last few laps - well done!
Kev
 Looking good Al and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (7)
