Where to buy Electric plank bender?? Options
rashaad430
#1 Posted : 27 May 2011 20:51:22
hi guys
looking to buy an electric plank bender in johannesburg, but none of the hobby shops seem to have it, n sometimes not even aware what it is...
any1 know where i can buy in SA? or maybe know a site where i can order one?
thanks a mil
#2 Posted : 27 May 2011 20:55:37
www.cornwallmodelboats.co.uk try them they will ship.
Mike Turpin
#3 Posted : 28 May 2011 00:11:29
Or ... save your money and use a small soldering iron. There are several threads recommending that!
Mike T
#4 Posted : 28 May 2011 00:28:56
or you can do what I do soak the planks fo 30 minuets and fit them, allow to dry then fit them permanently.
CMB
#5 Posted : 28 May 2011 11:09:05
Thats the way I fitted my planks after trying the soldering iron method.
No scorching,breaking or burnt fingers.
Takes a little longer but well worth it in the end.
Happy building
CMBBigGrin
Atholm
#6 Posted : 28 May 2011 11:09:34
Another option is to use a hair curling tong which is not as hot as a soldering iron and requires more patients.
Stowaway
#7 Posted : 28 May 2011 21:09:47
Hi,
I made my own from a 45Watt (I think) Stanley soldering iron( R89 at Checkers). I also used a jigsaw and some 25mm scrap wood to cut a few different curves to form the curves. Ten minutes of soaking the planks, and I'm cooking! If you are interested, let me know and I'll try to explain it more fully to you.
Good luck
Hans
#8 Posted : 30 May 2011 08:49:18
Drool I agree with the previous posts. You don't nessaserily need a plank bender. Soak the pieces and use a small soldering iron doe the job perfectly.Drool
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
rashaad430
#9 Posted : 30 May 2011 18:45:45
Happy building
CMBBigGrin
what about the plier typr bender that comes with the toolkit? does it work well?
soak them in hot water? how do you bend them after soaking?
appreciate the help guys...
Foz
#10 Posted : 30 May 2011 21:30:23
Hi there
had your problem myself and did not know what to do. In the end after much help from this forum i went for the soaking the planks ion hot water for around 20 mins then using a cheap soldering iron bend the planks in to shape.
I acctuly brought a proper electric plank bender and found that i had wasted my money.
Go for the soldering iron.
Hope this helps
Foz
#11 Posted : 03 June 2011 09:44:36
Hi Rashaad,
I have also gone with the soldering iron rather than a plank bender. I cut some profiles out of Kiaat with a jigsaw and sanded them smooth.
My method is as follows:
• Plane the chamfer on all 6 planks (Enough for 1 row)
• Fit the middle two planks
• Measure and cut the two bow planks roughly to size
• Drop them in a bottle of water
• Fit the two stern planks
• By this time the bow planks are soft enough to bend. Gently stroke the solder irons shank (Round part between the tip and handle) over the plank using the wooden former to obtain the correct profile. It will require a number of test-fits.
• Apply glue and pin in place. Wood glue (Alcolin type) is water soluble, therefore as the water evaporates, the glue dries – no waiting for parts to dry.
pierre50
#12 Posted : 13 September 2011 08:24:36
I also use a soldering iron, but I modified mine. Took a 20mm alluminium rod cut a 20mm piece drilled a 6mm hole in center and forced it over the soldering iron's tip, works great.
Current Buid:
HMS Victory
Next Build:
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
This page was generated in 0.132 seconds.
