 Rank: Beginner Level 3  Groups: Registered
Joined: 11/01/2018 Posts: 23 Points: 68 Location: Eastbourne
Hey, just some advice please , beacause i am new here i have only recently learned about the mix up with the 4 silver screws used for the foot plate! I had used the longer 6mm screws and it should have been the shorter screws. Will the longer ones i have used cause a problem later on? Can they be left? Or is it recommended to change them over ? Thank you Horlixs #CRAFT #BUILD #CREATE My YoutubePartworkUpgrades
 I think you should be ok to leave them in place . If you do run out of the long screws you can always swop them over . Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: I think you should be ok to leave them in place . If you do run out of the long screws you can always swop them over . Ok thats great thank you . :-) Horlixs #CRAFT #BUILD #CREATE My YoutubePartworkUpgrades
