Query around 1st plank Options
ravager
#1 Posted : 17 January 2018 02:27:47
Howdy all,
Just two questions around planking. The keel (I think) is it suppose to sit flush with the first plank laid on the bottom of the boat. I have a little bit of variance across the ribs to the keel and am trying to work out if I should sand them all so the first plank sits flush. ie 2mm
Second question is with the planks that bend around the end ribs are they fairly straight or have a slight s bend in them keeping the back of the boat slightly curved. I can't really see any good pictures at a angle to judge this.
Cheers
#2 Posted : 17 January 2018 07:25:33
BigGrin Hi mate if you could take some pictures of the keel and the stern I can see what's going on. Also what stage are you at Cool
Martyn
ravager
#3 Posted : 17 January 2018 07:41:24
Unfortunately I don't have a camera but as per tomicks post the first part of my query can be referenced in his picture
http://forum.us.model-sp...m/resource.ashx?a=13801
I am essentially asking if that first plank there sits flush the length of the ship as the gap on my ribs goes from flush to nearly 2mm. So if it suppose to sit flush with the planks I can evenly sand it so that it does.
2nd question referencing the build photos is about the curve of these planks around this area.
http://forum.us.model-sp...m/resource.ashx?a=14860
Do they all just have a gentle curve length ways or do they get nearly straight at some point or even a curve the opposite direction. I am just sanding the ribs in prep to starting planking and just want to get in my head how it is suppose to come out.
#4 Posted : 17 January 2018 08:01:26
Can you tell me which issue you are on and will have a look, cheers mate
Martyn
This page was generated in 0.167 seconds.
