19 Pages «<89101112>»
Gibbo's DelPrado Victory Build Options
Gibbo
#181 Posted : 07 January 2018 22:23:18
More bits being chopped off, there was a rather thick beam running underneath the front of the Poop Deck so to give myself a bit more of a chance of getting things in there it had to come out, the photo etch i bought which was originally designed for the 1/100 Heller plastic kit is a little oversize for this 1/100 so a bit of jigging around is going to be needed and all the space i can get i will take, i also had a bit of plastic grating and decided to make the flag lockers with that and frame it with a coffee shop stir stick.
Gibbo attached the following image(s):
Gibbo
#182 Posted : 09 January 2018 18:27:05
The Flag Lockers were shaped and painted and i didn't have to do much to them to make them fit with the angle of the transom due to the overhang of wood at the back of the lockers, just a bit of filing of the plastic to make them flush, i also added two Kevels either side of and just forward of the ships bell on the forecastle.
Kevels A.JPG (308kb) downloaded 23 time(s).
Kevels A.JPG (308kb) downloaded 21 time(s).
#183 Posted : 09 January 2018 19:18:16
BigGrin Hi Gibbo
If your looking for buckets try here:-
http://www.jotika-ltd.co...24768/Fitting_SfitA.htm
Gibbo
#184 Posted : 09 January 2018 20:43:34
arpurchase wrote:
BigGrin Hi Gibbo
Thanks Andy
#185 Posted : 09 January 2018 21:23:11
Hi Paul.
Flag lockers look really good. seems like your victory is having a major refit. look forward to seeing what you do with her.
Ian Cool BigGrin
#186 Posted : 10 January 2018 00:00:51
Another nice update, changes you're making is going to make the world of difference....Cool Cool
#187 Posted : 10 January 2018 11:47:36
You are doing a fantastic job with your Victory-rebuild!
Gibbo
#188 Posted : 11 January 2018 23:12:06
Thank you Walter, Ian and Alan for your comments, always very much appreciated, this time around i have been capping the Gunwales from the stern to the back of the forecastle with some coffee stirry sticks to give it a bit more width to take the photo-etch hammock cranes and adding the kevels on the quarter deck, i have also assembled the photo-etch skylight for the poop deck.
#189 Posted : 11 January 2018 23:43:13
Some nice work going into this.Looks excellent.
#190 Posted : 12 January 2018 01:03:08
Nicely done Gibbo and I do like that skylight, looking good.....Cool Cool
#191 Posted : 12 January 2018 10:53:27
That Skylight looks great!
#192 Posted : 12 January 2018 11:24:00
Looking great Paul!Cool That skylight saves so much work! Are you going to glaze it with acetate or the Micro-'whotsit' (can't remember the name of it now!)
Love the coffee stirrers, you wouldn't believe how many of those I've collected, half a dozen at a time. How did you bend yours over that curve?
(Sneakily collecting tips here!)BigGrin
Keep them coming!
Robin.
Gibbo
#193 Posted : 12 January 2018 12:59:15
Keep them coming!
Robin.
Hi Robin
I am planning to use the Humbrol Micro "whotsit", DaDokta used it recently on his skylight and i like the effect, if i decide to cut the deck open under the skylight and put beams in underneath i will probably use the acetate so you can see it, the coffee stirrers i soaked in water and used the stem of a soldering iron to get the tight curve, i had to curve the length of them as well for the poop deck and for that i used pins to get the gentle curve and left them to dry, i found some curved ones yesterday in a cafe while out walking the dog, but hey ho too late now.
#194 Posted : 12 January 2018 19:01:56
That'll teach me! I always look for the completely straight ones when I'm 'acquiring'BigGrin
Now I'm back home I've got the bottle in front of me and it's Micro Kristal Klear that I used on my skylight. It gives a lovely antique glass effect compared to the ultra clear acetate and you can still just make out the beams inside.
Great updates!
Robin.
Gibbo
#195 Posted : 12 January 2018 23:08:36
Great updates!
Robin.
well that's that then, Micro Kristal Klear or Humbrol clear Fix it is then, thanks Robin.
#196 Posted : 16 January 2018 12:41:17
Hi Paul.
skylight looks fantastic. are you going to glaze it using micro crystal clear.
Ian. Cool BigGrin
Gibbo
#197 Posted : 16 January 2018 14:31:01
ian smith wrote:
Hi Paul.
Ian. Cool BigGrin
Yes Ian i am, i bought some Humbrol Clear Fix.
Gibbo
#198 Posted : 16 January 2018 21:18:59
I have been working on the Poop Deck Rail, firstly i took the PE rail and to cut it down to make it fit, the Victory has eight posts on the rail but mine only has six i didn't really need to use it but it has the bucket handles attached to it and the PE wasn't cheap so i'm going to use as much of it as i can, the Heller plastic kit obviously has a wider beam than this one, the rail was made up of coffee stirry sticks and 3mm X 3mm square, the PE beam was glued on top and the hammock frames were attached in to each post, the netting is for another time and the buckets ? well i'm gonna have to think about that one.
#199 Posted : 17 January 2018 00:11:47
Very nice indeed Gibbo, love the detail......Cool Cool
Gibbo
#200 Posted : 17 January 2018 19:27:12
Today i received a large parcel, the Heller 1/100 scale of the Victory, i originally bought it to maybe barstoolise it for certain bits and pieces, it cost me £35 off ebay, not bad for a model that retails at around £130, i was mainly looking at it to see what the cannons were like and whether they could replace the DelPrado ones and also use the sweeping bow sections, but i think i'm going to use the bow section as a template and using the measurements recreate it out of wood so there will be more hacking bits off when the time comes, once i have what i need from it i will either build it OOTB or relist it, it's a lot of model for the money.
This page was generated in 0.277 seconds.
