5 Pages «<2345>
Chipping away at Falcon Build Options
#61 Posted : 16 November 2017 02:24:30
Well that modified landing pad is a very neat idea.
You really have come up with some incredible upgrades to your model and i am really enjoying seeing yours taking shape.
Hope it all continues well.
#62 Posted : 16 November 2017 08:25:35
Nice idea Chip. Look forward to seeing that soon.
kaledon
#63 Posted : 12 December 2017 19:19:11
Rank: Newbie
woooow,
do you sell your PCB and components infos?
Chip
#64 Posted : 13 December 2017 10:07:52
Rank: Amateur level 2
Location: Outer reaches of the galaxy .... West Midlands
Wasn’t the plan to go into production tbh but I do have a couple of boards spare, there are mistakes but can be easily rectified. I wasn’t planning on making any rectified boards but if there are 5 minimum I would, other than that if your happy with a current PCB I can provide a step by step. I am away at the moment (in London from The Last Jedi premiere, no spoilers but it doesn’t disappoint) send me a PM and I’m sure I can sort you out.
kaledon
#65 Posted : 14 December 2017 13:00:41
Rank: Newbie
Well, this is Alex from Rome/Italy
You'll find me on facebook (Alex Mele III) or via mail alexmelekaledon@me.com
bye
Alex
Chip
#66 Posted : 09 January 2018 21:55:19
Been working on my corridors in the little me time I’ve had over Christmas, before I add the leds for the wall lights there are a couple of adjustments needed:
1. A little bit of light leakage around the straight corridor’s instrumentation wall to be sorted.
2. After adding the mirrors on the end of the corridors which are approx 4mm thick you can see the led strips under the flooring (must admit I hadn’t considered this, but you live and learn) so will need to blank off the the area under the floor at the mirror end.
A few pics of current progress with ithe corridor being powered from the floor1 output of my board:
#67 Posted : 09 January 2018 22:05:45
Lovely work Chip, looks great. I’m sure you’ll sort out the light bleed. It will be all worth while when you see it all connected up inside.ThumpUp
Chip
#68 Posted : 10 January 2018 20:07:34
Solved my light leak problems using a little bit of black foam sheet I had from hobbycraft for god only knows what, thin malleable and easy to form to correct size and shape saved a lot of cutting and filling:
The tiniest sliver of foam indistinguishable from a build up of dirt in the crevice between the console wall and cushions prevents any light leak
Foam cut to the shape of the underfloor space squeezed in at ends of corridors:
Chip
#69 Posted : 21 January 2018 16:35:39
Built my static and flashing LED looms and connected them up to the hold so far, these same lines will provide static and flashing for both the turrets and cockpit too. Powered by 4 of the 12V outputs from my custom controller board the 3 differing flash rates and the static illuminate when applying cockpit power (as they power the cockpit lights), the dejarik table illuminates on activating hold lighting on the remote along with the corridor lighting, and the yet to be wired up bed light, inspection pit lighting and computer room lights.
Pretty happy with the effect so far but may tweak the flash rates in the code for a bit of a faster rate from one of the lines. Need to tidy up the corridor lighting as a bit of bleed through some of the covers and need to touch up the dejarik table as had to put more transparent paint on the fibres as was too white and with my twitches most of it ended up on the tables sides lol.
Here’s a quick video of the hold lighting so far:
https://youtu.be/lRQJv9nDMXs
#70 Posted : 21 January 2018 17:32:25
Very impressive, looking the biz now. If you are like me, I was always tweaking things.BigGrin
Chip
#71 Posted : 04 February 2018 22:00:49
It’s what’s inside that counts .... apparently according to the proverb well I wish it could be said the same for my falcon lol.
The hold is now approx 95% complete, I had been waiting on a back issue to arrive as I was missing a corridor arch. With that in my possession I set about the port corridor and also the communications room off to its side and the wall light between the two.
Port Corridor:
Port Corridor Lit:
Comms Room (forgot to take pics during construction):
There are a number of touch ups required, the corridor lights are showing a few leaks through the light shades, which were a complete beggar to fit, somebody a damn site more talented than me really needs to make 3D printed corridor cushions with accurate lights built in!
I still have the bed light to wire up, the holds console chair to paint, various cargo pieces and I’m still debating whether to do the forward hull wall pipe and pillars but for now I’m going to put the hold to rest for a little while and start work on the lower hull so I can actually start placing the hold and it’s lighting lines etc.
Various hold pics:
#72 Posted : 04 February 2018 23:03:23
Nice pictures, looks excellent. Soon be fitted into the Falcon.BigGrin
Chip
#73 Posted : 01 January 2019 22:51:28
Wow I can’t believe it’s been 10 months since I posted here or did any real progress to my Falcon, 1000 apologies to anyone who has been following this but I have been suffering from health issues and in what spare time I have had has been taken up with other projects:
Built and cleared my Biker Scout with the UK Garrion 501st Legion:
Designed and 3D printed my Biker Scout EC-17 Blaster, with full electronics. This was the first EC-17 with special effects cleared with the UK Garrion 501st Legion:
https://youtu.be/7lmLP8glfeY
Also designed and 3D printed my Biker Scout DLT-19X Sniper Rifle, I did this so I had something to use as a walking stick if I began to tire during a troop (which is happening more and more often). Again this included full electronics and I decided to try and make a HUD type scope, the reason.... just because really lol. This again was the first DLT-19X with special effects cleared with the UK Garrion 501st Legion:
https://youtu.be/YbB-xKhYxKk
Anyway back to the falcon, after resetting all my previous image links due the hosting site I used changing its servers I can now share my recent update:
I have built the lower hull, filled in the tv mount screw holes as I won’t be using this, sprayed the layer with Tamiya Insignia White and drilled and installed landing light LEDs and the red anti-collision lights.
I snipped and soldered the 4 main 5mm landing lamps to join them to my smaller landing lights wiring looms.
I checked these worked correctly with my phone Blynk controller..... so far so good 😊
I purchased Anti-Coll shrouds via shapeways and these will be added following painting of the lower hull which I hope to get round to in the couple of days.
So the New Year is now with us and I endeavour to make the Falcon a priority in my to do list in the hopes of finishing it within 2019. But until then I wish everyone a happy new year and wish you health and prosperity for the year to come.
#74 Posted : 02 January 2019 08:06:42
Sorry to hear of your health matters and good to see your back. Should look amazing when complete Cool
Chip
#75 Posted : 07 January 2019 21:01:58
Cheers Tomick, unfortunately now getting to the part I dread ...... the painting Blink
Watched numerous YouTube videos on weathering and oil washing and after stalling for as long as I could I finally got down to it.
Hull now painted and, I think, sufficiently weathered, amazing how cleaner it looks in a picture compared to reality though.
Took a series of pics with/without room lights:
#76 Posted : 07 January 2019 23:08:43
Lovely job, looks excellent. Nice to see you back on this again.Drool
Chip
#77 Posted : 15 January 2019 20:11:32
Worked on the undercarriage and the lower cannons pleased it seems to be taking shape, but it really needs some undercarriage doors before I move on to fitting the internals. I plan to install fibre optics into the top cannon only as both firing at same time would look odd.
#78 Posted : 15 January 2019 20:36:32
Nice to see you back chip, with another great update ThumpUp
Great work Love
#79 Posted : 15 January 2019 23:47:22
Nice work Chip, and great to see you back on it again. She’s dirtying up very nice, not overdone.Love
Chip
#80 Posted : 20 January 2019 21:56:01
Undercarriage doors arrived this week, bought from Shapeways through 308Bits who I’ve purchased most of my 3D printed parts from, including the hollow rear legs for passing the power wires through.
Doors painted, panel lined, oil brushed and a bit of weathering powders applied. Glued into place, they make the lower hull look more realistic and love how they illuminate with the landing lights.
I tried to friction fit the lower cannon, but it still droops (very slowly though) with gravity, think I’ll end up blueing it in place, otherwise the ends of the cannon end up touching the floor (or more accurately the table at present Flapper )
After that I think that will be the lower hull done and I’ll mount the hold and my controller board so I can move it all to a safe place whilst I work on the top hull.
ThumpUp
Guest (11)
5 Pages «<2345>
This page was generated in 0.293 seconds.
