7 Pages «<4567>
Ian's E-Type build diary Options
Ian23
#101 Posted : 07 January 2018 15:44:49
Build the Jaguar E-Type, Stage 41
Parts with Issue 41
Tyre
washer
Take the Tyre and place it in boiling water for a few minutes to soften. remove it from the water and dry thoroughly. before the rubber cools push the rim of the wheel into the Tyre and stretch it around the whole wheel. It will take some force.
Take the subframe assembly and align the lugs on the back of the hub with the notches on the right front axle. Take the washer and place it into the hub so the holes align and secure it with a single screw. Make sure the wheel spins freely (Picture 2)
Ian23 attached the following image(s):
Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Built: Deagostini Millennium Falcon
Ian23
#102 Posted : 07 January 2018 15:47:01
And that finishes another month. The wheel this time wasn't as difficult, Probably because i had done one before. I managed to go the 3 spoke method and i got the outer spokes right this time.
the next issues will be good as it looks like we are getting the rest of the floor assembly. Its going to get bigger faster now!!
#103 Posted : 07 January 2018 17:35:02
Great work Ian BigGrin coming along nicely.
Ian23
#104 Posted : 27 January 2018 18:52:06
Another month and another set of parts
Build the Jaguar E-Type, Stage 42
Parts with issue 42
Front floor assembly
This issue contains the front half of the floor. Nothing is done with it in this issue
Ian23
#105 Posted : 27 January 2018 18:54:27
Build the Jaguar E-Type, Stage 43
Parts with issue 43
Rear floor assembly
Take the 2 floor panels and fit them together lining up the screw holes. Secure the panels together with 4 screws (picture 2)
Ian23
#106 Posted : 27 January 2018 19:00:53
Build the Jaguar E-Type, Stage 44
Parts with Issue 44
Lower casing
Upper casing
Right hand rear brake
Left hand rear brake
Right hand universal Joint
Left hand universal joint
Bonnet catch plate
Take the brake and the universal joint marked with an L and fit them together. Repeat with the parts marked R. (Picture 2)
Secure the assemblies to the lower casing with a single screw each. (picture 3)
Fit the upper half of the casing to the assembly and secure with a single screw. (picture 4)
Take the bonnet catch and position it into the hole in the front subframe. Secure from behind with a single screw (picture 5)
Ian23
#107 Posted : 27 January 2018 19:06:30
Build the Jaguar E-Type, Stage 45
Parts with issue 45
Rear Subframe
Handbrake Linkage
Take the drive assembly from stage 44 and position it into the rear subframe. Secure from below with 2 screws. (picture 2)
next take the handbrake linkage and align it with the assembly. Push the pin into the hole and position the two arms over the holes in the subframe. secure the linkage with a screw through each arm. (picture 3)
#108 Posted : 27 January 2018 22:36:59
looking good Ian BigGrin nicely done.
#109 Posted : 28 January 2018 11:03:02
Looking very nice BigGrin
stevegbr
#110 Posted : 28 January 2018 11:56:07
looking good ian. BigGrin keep up the good work.BigGrin
#111 Posted : 28 January 2018 17:15:44
Nice work Ian BigGrin regards PhilCool
#112 Posted : 28 January 2018 18:45:40
BigGrin Looking good IanCool
#113 Posted : 28 January 2018 19:09:15
coming along very nicely Ian.
Ian23
#114 Posted : 24 February 2018 17:35:20
New month, new parts YAY!!
Build the Jaguar E-Type. stage 46
Parts with Issue 46
Shock Absorber bodies
Shock Absorber pistons x2
Coil Springs x2
Hub Carrier
Left-hand wishbone
Left-hand halfshaft
Universal Joint
Mounting plate
Long spindle
Medium Spindle
Short Spindle x3
Take the shock absorber bodies, coil springs and pistons. Slot a spring over one of the cylinders on the shock absorber body. Fit one of the pistons onto the top of the spring and secure it by fitting a screw into the end of the piston shaft. repeat for the second shock absorber (picture 2)
Take the assembly and secure it to the subframe assembly with the mounting plate (picture 3)
Take the half shaft and universal joint. Fit the joint into the end of the half shaft without the lug. Push and secure the joint to the shaft with a short spindle. Fit the fork over the universal joint and secure with another short spindle (picture 4)
Take the wishbone and taking note of the alignment. Ease the 2 eyes from the shock absorber over the pins on the wishbone and align with the holes in the subframe. secure the shock absorber eyes with screws on each side. Take the last short spindle and push it through the shorter of the 2 holes on the wish bone. Secure the opposite side with the medium spindle. (picture 5)
hake the hub carrier and position it over the universal joint. secure it to the wishbone with the long spindle (picture 6)
Ian23
#115 Posted : 24 February 2018 17:38:48
Build the Jaguar E-Type, Stage 47
Parts with issue 47
Coil Springs x2
Hub Carrier
Right-hand wishbone
Right-hand halfshaft
Universal Joint
Mounting plate
Long spindle
Medium Spindle
Short Spindle x3
This is basically identical to issue 46
Take the half shaft and universal joint. Fit the joint into the end of the half shaft without the lug. Push and secure the joint to the shaft with a short spindle. Fit the fork over the universal joint and secure with another short spindle. Take the wishbone and taking note of the alignment. Ease the 2 eyes from the shock absorber over the pins on the wishbone and align with the holes in the subframe. secure the shock absorber eyes with screws on each side. Take the last short spindle and push it through the shorter of the 2 holes on the wish bone. Secure the opposite side with the medium spindle. (picture 4)
hake the hub carrier and position it over the universal joint. secure it to the wishbone with the long spindle (picture 5)
Ian23
#116 Posted : 24 February 2018 17:49:23
Build the Jaguar E-Type, Stage 48
Parts with issue 48
Rear anti-roll bar
Bracing plate
Right-hand radius arm
Left-hand radius arm
Mounting brackets x2
Safety straps x2
links x2
Take the anti roll bar and fit the links over the lugs at the ends of the bar. Fit the 2 radius arms onto the other ends of the links (picture 2)
Lay the assembly onto the underside of the floor assembly. Fix it to the floor assembly with the 2 mounting brackets. (picture 3)
Flip the radius arms over and position them over the holes on the floor. Secure the radius arms to the floor with the safety straps as shown (picture 4)
Take the subframe assembly and fit it into the car floor assembly aligning the holes in the wishbone with the lugs on the radius arms. Secure the subframe with 4 screws (picture 5)
Fit the bracing plate to the subframe and secure with 2 screws (picture 6)
Ian23
#117 Posted : 24 February 2018 17:53:46
Build the Jaguar E-Type, Stage 49
Parts with issue 49
Silencer upper half
Silencer lower half
Take the 2 halves of the silencer and fit together securing with 4 screws (picture 2)
position the silencer onto the underside of the floor matching the posts with the holes. Secure with 2 screws (picture 3)
Ian23
#118 Posted : 24 February 2018 17:54:56
Another month down and its really looking good now. Next month it looks like another wheel (cry)
Ian23
#119 Posted : 18 March 2018 16:26:57
Hi guys,
I got this months issues and have built the wheel, I won’t be posting a build diary for them as I have already done that for 2 wheels. If your interested feel free to go back and look at issues 39 - 41.
It’s really starting to come together now and as soon as the wheels are done and we can start properly building body it’s going to look amazing
#120 Posted : 18 March 2018 16:39:11
Looking good Ian and looks like you are really enjoying this build.
Well done so far. Cool Cool Cool
7 Pages «<4567>
This page was generated in 0.273 seconds.
