Joined: 06/08/2015 Posts: 276 Points: 817 Location: Monrovia, Ca
Hi Everyone, I saw this one when it came out in the U.K. earlier this year and knew I would have to get it if I ever got a chance.  Well, I saw an add for it here in the U.S. a couple of weeks ago and jumped right on it. I received the first two issues with my first shipment. In Issue #1, we get the back end of the DeLorean including a taillight, bumper and the icon " Outatime" license plate. In Issue #2, we get the other taillight and a front fender. There are several different screws for this build, so i got myself an weekly pill container at the Dollar Store to safely store everything. I also picked up some detailing towels to use for this build and for storing completed parts. The parts seem to be of good quality and the build seems to be pretty straight forward. Not really much to paint or construct on this one, so the build should be fairly easy compared to the Millennium Falcon where I had to paint every part. Here are a few photos of the progress so far. Regards, Stephen scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Finished Builds: Millennium Falcon
 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
looking good, i am building this as well, it is a fun build, and it gets very heavy, enjoy your build.
Another build to watch with interest  looks like a great kit not started mine as yet  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thank you for looking in, Steve and Phil. Should be a fun build. Don't have much to show off yet, but will post again after the next shipment. Steve - Since you are further along on this, have you encountered any issue with the kit that I should be careful of? I saw one guy on Youtube who had a wheel break of due to a rather flimsy linkage between the front wheel and the chassis. Just want to avoid any problems. Regards, Stephen Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
I think as long as you are careful you will be OK. When you put the screws for the wheels eg. Don't take the screw down in one go. Turn it down a couple of turns and reverse back. You will find easier.any problems don't be afraid to ask. There are some clever modellers on here with good advice and will share with you.
stevegbr wrote:I think as long as you are careful you will be OK. When you put the screws for the wheels eg. Don't take the screw down in one go. Turn it down a couple of turns and reverse back. You will find easier.any problems don't be afraid to ask. There are some clever modellers on here with good advice and will share with you.
Thanks, Steve. I will let you know if I have any issues. Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Hi Everyone, I hope you all had a great holiday break. I know I was quite busy and didn't have a lot of time for modeling. Now, with everything getting back to normal, I will try to catch you up with my many builds. In the second shipment of parts for the DeLorean, we get issues 3-6. Issue 3 has us building our first wheel. The assembly was pretty straight forward. The rim feeds through the tire and the hubcap is secured with 3 screws. The hub and a small washer are then pressed into the center of the hubcap to complete the assembly. scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
In issue 4, we get the the Mr. Fusion and the reactor disc. The reactor assembly was fairly easy. A few screws to hold everything together. Mr. Fusion took a bit more work, but wasn't nearly as bad as I thought. There were a couple of very tiny springs to add to the hinge at the end, but tat wasn't too difficult. Then, I decided to fill in the screw holes on Mr. Fusion and that is where it went all wrong.  I wound up ruining the wording on that side of the piece and was unable to fix it. I decided to contact Eaglemoss and try to purchase another Issue 4. I explained to their rep what had happened and offered to pay for a new issue. They were very gracious and said they would send out a new issue 4 at no charge.  I must say that I was very impressed with their customer service after hearing so many bad things about them. scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
In issues 5 and 6, we get the left and right front suspension and brake. Assembly involves attaching the lower link to the upper suspension, adding the shock absorber and coilspring. The tie head is attached and the disc braked and caliper are assembled. Finally, the brake assembly os attached to the suspension assembly. scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Great start  will be following  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thanks Phil for looking in. In issue 7, we get parts for the steering rack, linkage and front plate. Assembly involves connecting the pinion and pull rod to the steering rack with a couple of screws. The rubber boots are then added on either end to complete the assembly. The first picture shows the parts that come with the issue along with my growing screw collection. The second picture shows the assembled steering rack along with the front plate which will be used in later issues. scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
In issue 8, we get the anti-roll bar and the bottom plate. Assembly involved connecting the left and right anti-roll bar bases to the bottom plate. scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
In issue 9, we get our second front wheel. Assembly was the same as in issue 3. The picture shows the parts layed out before assembly. scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
In issue 10, we get the full frame piece and a wide variety of screws. The assembly on this issue begins with adding the wheel hub assemblies from issues 5 and 6 to the front of the main frame. Then, the front plate and steering rack are added. A bit of finessing was required to get everything to operate smoothly. Once I had all the screws adjusted correctly, the bottom plate was attached to the underside of the front plate. The anti-roll bar was then added to the frame and finally the front wheels were attached. I was very happy with how this came out and you can really get a feel for the size of the DeLorean at this point. Regards, Stephen scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,867 Points: 20,918 Location: Northamptonshire, England
You are certainly cracking on with it. Look great. Mark Regards Markwarren (Mark) Admin
looks great  how many issues have you collected so far ? regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
tigerace wrote:looks great  how many issues have you collected so far ? regards Phil Thanks for you comments, Mark and Phil. I'm up to issue 18 at this point, Phil. Got a bit behind in my diary posts. Trying to get things caught up. Regards, Stephen Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
In issue 11, we get the the engine support and connecting rods for the rear section of the frame. Assembly involves attaching the connecting rods to the engine support. The engine support piece has two other pieces that attach to either end. The entire assembly is then attached to the underside of the rear frame. scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
In issue 12, we get parts for the left rear hub and suspension. Assembly involves attaching the hub to the hub carrier piece and the track rod. This assembly is then attached to the main frame. The shock absorber and spring is then added. The caliper is added to the disc brake and attached to the hub. The front left track rod is then assembled and stored for safely to be added later on. scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
in issue 13, we get our first rear tire which is slightly larger than the front tire. Assembly is the same as the front tires. The tire was then attached to the left rear hub. scraperjawa attached the following image(s): Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
