No real reason to await the arrival of the dome when you could be getting on with the rest of what you have. Obviously your not going to be left with just legs etc
Joined: 19/01/2017 Posts: 64 Points: 216 Location: UK
Tomick wrote:No real reason to await the arrival of the dome when you could be getting on with the rest of what you have. I know ! A self imposed restriction I set myself , when I realised that some of the build was about a minutes worth of work , wanted something I could really get my teeth into ! Tomick wrote: Obviously your not going to be left with just legs etc Yeah I kinds knew that , I was just making mirth .... I shall endeavour to refrain from trying again ! SOME MORNINGS IT JUST DOESN'T SEEM WORTH IT TO GNAW THROUGH THE LEATHER STRAPS
You might actually want to crack on with the build as you may yet need to have the projector replaced or something else and will then be waiting for the arrival of the replacement parts
Joined: 04/08/2017 Posts: 73 Points: 243 Location: Missouri, USA
Agree with at least assembling the two issues making the projector. 27 & 29? Many people have had to get a board replacement.
Wow , didnt realise that so many things went wrong on this build , seems like they have a lots of part and quality issues , I best start straight away , thanks guys I'm on it , hopefully some of my parts will still work ! .... SOME MORNINGS IT JUST DOESN'T SEEM WORTH IT TO GNAW THROUGH THE LEATHER STRAPS
PhilC wrote:Wow , didnt realise that so many things went wrong on this build , seems like they have a lots of part and quality issues , I best start straight away , thanks guys I'm on it , hopefully some of my parts will still work ! ....
Would you care to define “lot’s of part and quality issues” because it’s simply not true
My grandson is building this kit under my supervision, he's only 8 and to date we have encountered one minor issue with the projector which was very quickly rectified by CS. Almost at the half way point now with no other issues encountered so can't quite see where you see lots of parts and quality issues.... Regards Alan
I`m up to stage 48 and not a single problem. Everything working fine. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
The only issue I had was with the projector which was quickly rectified, everything else has gone together like a dream.
