2 Pages <12
Quick question Options
#21 Posted : 29 December 2017 12:53:52
No real reason to await the arrival of the dome when you could be getting on with the rest of what you have. Obviously your not going to be left with just legs etc
PhilC
#22 Posted : 29 December 2017 13:07:00
I know ! A self imposed restriction I set myself , when I realised that some of the build was about a minutes worth of work , wanted something I could really get my teeth into !
Yeah I kinds knew that , I was just making mirth .... I shall endeavour to refrain from trying again !
Blushing
SOME MORNINGS IT JUST DOESN'T SEEM WORTH IT TO GNAW THROUGH THE LEATHER STRAPS
#23 Posted : 29 December 2017 13:10:54
You might actually want to crack on with the build as you may yet need to have the projector replaced or something else and will then be waiting for the arrival of the replacement parts
#24 Posted : 29 December 2017 13:14:14
BigGrin The dome appears in issue 51 and little is done with it over the next 12 apart from adding blue panels until we get to issue 64 when a good deal of the sub-assembly's are fitted.
The two legs as they stand will give your more than enough grissle to chomp on if you start assembling nowLOL BigGrin Drool Cool
tschwand
#25 Posted : 29 December 2017 14:39:47
Agree with at least assembling the two issues making the projector. 27 & 29? Many people have had to get a board replacement.
PhilC
#26 Posted : 29 December 2017 15:59:51
Wow , didnt realise that so many things went wrong on this build , seems like they have a lots of part and quality issues , I best start straight away , thanks guys I'm on it , hopefully some of my parts will still work ! ....
#27 Posted : 29 December 2017 17:09:47
Would you care to define “lot’s of part and quality issues” because it’s simply not true Angry
#28 Posted : 29 December 2017 17:36:18
My grandson is building this kit under my supervision, he's only 8 and to date we have encountered one minor issue with the projector which was very quickly rectified by CS. Almost at the half way point now with no other issues encountered so can't quite see where you see lots of parts and quality issues....Mellow Mellow
#29 Posted : 29 December 2017 17:58:21
I`m up to stage 48 and not a single problem. Everything working fine.
Cool Cool Cool Cool Cool
#30 Posted : 29 December 2017 19:06:00
The only issue I had was with the projector which was quickly rectified, everything else has gone together like a dream.
2 Pages <12
