Ship Builders Starter Tool Set Options
#1 Posted : 28 December 2017 23:34:49
Initial Tools – enough to get you started with any ship build:
Modelling Knife and supply of blades
Fine Razor saw
Micro Drill and various sized drill bits.
Map Pins/Dressmaking Pins
PVA Adhesive
Superglue
Cutting Mat
Set of Needle Files
Nail Files/Emery Boards
Various size sanding blocks
Various grades of sandpaper from course to very fine.
Various Clamps plus clothespins
Tweezers
Steel Rule & Set Squares
Plank Bender
Building Jig/Dry Dock - https://forum.model-spac...spx?g=posts&t=20425
Paints – Acrylic
Paint Brushes – various sizes
Masking Tape
Pin Pusher
The above will give you a good start into the world of Ship Building.
As you proceed with your build then you may like to consider tools such as:
Airbrush & Compressor
Calipers
Paint Thinners and Airbrush Cleaner.
Airbrush Holder
Dremel with various attachments.
Drill Stand
Bench Vice
Optivisors
Desk Lamp with magnifier
Matt & Satin Varnish
This page was generated in 0.080 seconds.
