 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
the handbrake is attached to the sill. stevegbr attached the following image(s):
the sill is attached to the drivers side. stevegbr attached the following image(s):
Looking superb Steve, All those wires look fun, but can see you having to be very careful when the parts start coming together. That`s just to make sure they all lay in the right place in the end. Wishing you luck, have fun with the ongoing build. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,869 Points: 20,924 Location: Northamptonshire, England
Looking good Steve, plenty of cables to keep you going for a while. Mark Regards Markwarren (Mark) Admin
delboy271155 wrote:Looking superb Steve, All those wires look fun, but can see you having to be very careful when the parts start coming together. That`s just to make sure they all lay in the right place in the end. Wishing you luck, have fun with the ongoing build. Regards delboy271155 (Derek) totally agree with you derek, i am hoping it will not be too difficult, fingers crossed.
Markwarren wrote:Looking good Steve, plenty of cables to keep you going for a while. Mark more cables in the next issue mark.
here is issue 53. stevegbr attached the following image(s):
parts for this issue. stevegbr attached the following image(s):
put the two pipes together which go down the passenger side. stevegbr attached the following image(s):
now for the passenger sill. stevegbr attached the following image(s):
now for the wires for the passenger side. which are grouped together with two plastic ties. stevegbr attached the following image(s):
You certainly need some patience with this part of your build. That all looks quite complicate with all those wires having to be fitted. Certainly looking the part though. Hope it all continues well. Happy Modelling
Wow..lots of wiring in this build. Coming on very nicely. Malc.
Nice update steve  i think i will get a migrane when i get to all those wires  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
thanks guys, the wiring is a nightmare, the last two issues are not to bad, secret is i think not to try and finalise the position of the wiring when you are fitting it, because further along you will need to disturb it. if you see what i mean.
here is issue 54. stevegbr attached the following image(s):
here are the parts for this issue. stevegbr attached the following image(s):
wires are connected to the block, then connected to the bulkhead, then secured to the floor. stevegbr attached the following image(s):
now the parts which fit on the bulkhead. please note: the two pipes face to the back, not as it says in the instructions. stevegbr attached the following image(s):
here is issue 55. stevegbr attached the following image(s):
