11 Pages «<45678>»
Roy's E Type Options
#101 Posted : 18 December 2017 14:00:00
The first front wheel has now been half assembled.
Each wheel is clearly going to get easier as 'practice' takes place.
Looking forward to more parts.
Roy.
#102 Posted : 18 December 2017 14:50:54
That is look very nice Roy.
#103 Posted : 18 December 2017 15:02:04
great update RoyBigGrin big beastBlink regards PhilCool
#104 Posted : 03 January 2018 13:20:06
The rest of the front wheel all done, and the tyre fitted.
I know there are some who are having difficulties assembling the wheels but TBH, I'm not having problems.
For me, the hardest part is getting the tyre onto the rim.
A good 2-3 minute soaking in VERY hot water does the trick though.
A bit of advice - fit the rim into the tyre from the rear so if you need to 'urge' the tyre over any part of the rim with a teaspoon handle or whatever, you won't cause any damage to the outer face of the wheel.
Roy.
#105 Posted : 03 January 2018 13:31:41
The wheels do look good.BigGrin
#106 Posted : 03 January 2018 19:28:22
BigGrin Looking good RoyCool
goldfinger
#107 Posted : 07 January 2018 12:26:53
Message was deleted by User.
#108 Posted : 07 January 2018 12:57:27
Sorry - no idea about that one so I can't help.
These kind of questions really ought to be in general discussion though.
BigGrin
Roy
goldfinger
#109 Posted : 09 January 2018 12:39:37
Eagle
#110 Posted : 09 January 2018 13:59:39
Red Medal: Red Medal
I admire the wiring harness detail you are adding; may I ask what did you use to wrap the wiring to make the harness?
#111 Posted : 09 January 2018 14:13:27
The harness was made by using white fabric surgical tape - any chemist sells it.
It's very thin, very sticky.
Lay a strip out on your cutting mat, colour it black with a marker pen.
Cut into strips about 5mm wide and then wrap diagonally along the length of your wires...
Roy.
#112 Posted : 11 January 2018 22:37:57
Only a small update here.
The two floor panels have been screwed together and the front end assembly placed just to see how it all looks.
Next job - repaint the underside of the floor panel(s) so they are the same colour as the body.
E types originally had the entire shell painted the body colour which included underneath.
The only time the underside was black was when a customer chose the 'optional extra' of underseal.
Hence - the majority of E Types began rusting away long before their time as back in the '60's, nobody thought about rust prevention and for most, underseal was a waste of money as they didn't plan to keep the cars long enough to make it worthwhile.
Nowadays, E Type enthusiasts would be horrified if the underside of their prize 'show' car was black!
As an aside, I've made two new seats (yes, again...) in resin and trimmed them in tan.
That's the seats FINALLY done - honest...
Roy.
#113 Posted : 11 January 2018 23:49:39
Great work Roy, the seats look fab.
#114 Posted : 12 January 2018 14:54:07
Thanks Mark.
I've primed the floor panel and given it a first shot of Jaguar racing green.
It's the correct colour, mixed at a paint factor near me, according to genuine Jaguar paint codes etc.
You can see the panel has only had one layer of green so far.
Due to the numerous raised and recessed panels and bits, getting an 'all over' coat isn't possible in one or two passes without getting pools and runs.
I'll leave it for 24 hours and give it another few coats which will (hopefully) result in a nice green underside to the car.
#115 Posted : 12 January 2018 22:44:44
Looks good done in the green Roy BigGrin
#116 Posted : 13 January 2018 01:26:09
Loving the detail touches Cool
#117 Posted : 13 January 2018 11:00:30
Impressive as usual Roy, love the extra detail you're applying.....Drool Drool
stevegbr
#118 Posted : 13 January 2018 11:35:47
looking great roy, impressed with your seats, keep up the good work.
#119 Posted : 29 January 2018 10:38:32
I'm trailing a little bit behind with the E Type as I've been working away on the Porsche 911, and completing the Mustang.
Time to get back to the Jaaaag.
The floor panels have finally been given a couple more coats of green to match the body.
The rear diff cage etc will be next.
Roy.
stevegbr
#120 Posted : 29 January 2018 11:11:37
Looking good as always Roy. BigGrin
11 Pages «<45678>»
This page was generated in 0.213 seconds.
