3 Pages 123>
RAF100 build entry - Bristol F.2b fighter Options
#1 Posted : 17 December 2017 17:00:50
Hi All this will be my comp entry. not I am not in this to win it just for the fun of taking part and its a good excuse to build this kit from my stash!!
this will be a straight box build other than I ma rig the wings which is described in the instructions but no material is provided for it
here are some pics
Box art and 4 sprue of parts that I think were manufactured by Eduard originally and re branded as Revel.
#2 Posted : 03 January 2018 08:49:13
Not seen one of these built in a long time, interesting choice and great to have another RAF100 entry ThumpUp
#3 Posted : 03 January 2018 19:26:26
BigGrin Nice to see another build in the compCool
#4 Posted : 03 January 2018 22:28:02
Looks a very nice kit Jase and one of my favourite fighters from WWI along with the Royal Aircraft Factory SE.5a. Should build into a cracking model.
Best of luck in the competition mate. Cool ThumpUp
#5 Posted : 03 January 2018 23:44:28
Good luck with it, nice choice of kit....Cool Cool
#6 Posted : 06 January 2018 19:07:48
hi Jase.
look forward to seeing this one come together.
Ian BigGrin
#7 Posted : 09 January 2018 21:19:54
Thanks everybody for looking in.
Chocks Away!!!
First of all I have a little correction to make, this won't quite be a straight box build, I got the Eduard etch for it, sorry could not help it Blushing Drool Flapper
So lets get stuck in, first job was to prime all the parts on the sprue, Halfords grey, my trusty primer of choice most of the time.
Build actually starts with the floor pan of the cockpit, not sure if that was the correct term for the early birds but you know what I mean. Paint used is Tamiya silver, dark sea grey, medium grey and titanium silver. Inside the fuselage halves I used burnt siena artists tube paint.
Peddles and joystick on first and another lever, not sure what it is, then the floor was painted followed by the other parts of the assembly thus far.
next on was a brass pump, like a bicycle pump this was painted in AK true metal oil
while that lot was drying I gave the fuselage halves their foundation colour.
#8 Posted : 10 January 2018 23:08:03
Hi Jase
How on earth do you find the time to build all your models? Excellent start. I’m sure you’ll do her justice. Good luck with your build and the competition. Cool
Regards Gray
#9 Posted : 12 January 2018 20:53:41
Nice start Jase, looking good so far. ThumpUp
#10 Posted : 12 January 2018 22:12:45
Good start.
Hope it all goes well for you.
#11 Posted : 12 January 2018 23:59:53
CaptnBirdseye wrote:
Hi Jase
Regards Gray
To be honest this little kit is just that so when something is drying on Mikasa I jump onto my other desk to do a bit of this, and once my railings come I will do the the same with the Duchess build, good job I have three work desks LOL LOL LOL
Thanks for looking in
#12 Posted : 13 January 2018 00:02:32
Thanks Trev and Tony for looking in and taking the time to leave a few words of support, always appreciated
#13 Posted : 13 January 2018 00:21:05
Good to see a start on this, good luck with the RAF100 entry Cool
#14 Posted : 13 January 2018 13:44:01
Many thanksBigGrin
#15 Posted : 13 January 2018 13:51:00
The build continues with the two engines side sections. These should be painted Aluminium but I chose titanium silver to allow for a wash. some parts of the engine are picked out in dark grey.
I used a dark grey with a spot of brown and heavily thinned to create an oily looking wash.
the to parts are put aside for future assembly.
#16 Posted : 14 January 2018 21:10:40
Having given the Engine sides a wash as described above they can be installed into the fuselage halves. not much of the engine is seen but a bit is.
I then moved onto the pilots dash. the raised dials of the plastic part were removed with a file. the back of the dashboard is painted mid grey and the first etch part is fixed in place.
The next piece goes on top put the dials behind the wood effect etch facia.
a smal pence of etch is then added to the bottom of the assembly. that nearly finishes the dash other than I want to give the dials some glazing.
I then gave it a wash using a dark was for grey warships. The camera flash makes this look less subtle than it really is.
#17 Posted : 14 January 2018 22:26:39
Nice work Jase, like the wash on the engine, makes it look suitably oily and leaking as you would expect from WWI engines. Like the instrument panel too.
Well done. ThumpUp
#18 Posted : 14 January 2018 23:15:42
Just looking at all of those parts you get in this kit. Its very detailed .
It will all look really nice when complete.
#19 Posted : 14 January 2018 23:59:47
That’s a tiny panel though it’s cut or placement looks slightly off place at the bottom left, all the same should look great in the cockpit, we’ll done Cool
#20 Posted : 15 January 2018 09:52:54
Many thanks all for looking in and the kind words of support.
I only noticed the slight misalignment of the dash from viewing the photo. I have decided to not rusk causing damage by removing and setting again, although most likly douable, i feel it wont bee seen one the part is in its final position
3 Pages 123>
This page was generated in 0.215 seconds.
