10 Pages «<45678>»
Malc's Mclaren M19C Options
#101 Posted : 16 December 2017 00:19:13
Now thats a detailed engine. Great casting detail.
Chris Cool
#102 Posted : 16 December 2017 12:15:48
Thanks for the kind comments guys.BigGrin
There is a lot of detail on these castings which makes the build process very enjoyable.
Here's the cam shafts in place.
#103 Posted : 16 December 2017 12:18:10
Assembled block and heads.
#104 Posted : 16 December 2017 19:25:54
BigGrin Looking good MalcCool
#105 Posted : 17 December 2017 15:02:40
Fab build Malc, and as ever great attention to detail Cool
#106 Posted : 24 December 2017 10:20:49
More small castings to prep' BigGrin
#107 Posted : 24 December 2017 10:22:03
I've gone for a combination of polish and paint.
#108 Posted : 24 December 2017 10:24:57
#109 Posted : 24 December 2017 10:26:06
#110 Posted : 24 December 2017 13:17:32
BigGrin Looking top notch Malc great workCool
#111 Posted : 24 December 2017 16:52:44
Wonderful looking build.
Hope it all carries on as well for you.
#112 Posted : 27 December 2017 11:32:29
Thanks for looking in Guys and for the kind comments.
#113 Posted : 31 December 2017 08:47:28
The throttle slides are mounted on top of the Manifolds.
#114 Posted : 31 December 2017 08:48:38
The trumpets need a little fitting to get them seated nicely.
#115 Posted : 31 December 2017 08:52:14
Now.... these springs and the PE parts that get mounted on the manifold tops are incredibly small ( toothpick shown for reference BigGrin ).
A short length of the supplied springs has to be cut off and the end formed before attaching.
Was a bit frustrating but got a method sorted in the end.
#116 Posted : 31 December 2017 08:55:00
The injector pump is this octopus which sits between the manifolds and the fuel lines run out to the injectors.
#117 Posted : 31 December 2017 08:56:10
Finished assemblyBigGrin
#118 Posted : 31 December 2017 09:18:21
BigGrin Excellent work Malc, those small springs are a challenge until you sort out the method to do themCool
#119 Posted : 05 January 2018 14:40:19
Moving on from the "micro-springs".... Made my first PE folded box for the electronics. Pleased with that.BigGrin
#120 Posted : 05 January 2018 14:42:12
Just to see what it's starting to look like.
10 Pages «<45678>»
This page was generated in 0.316 seconds.
