Joined: 19/05/2015 Posts: 1,419 Points: 4,272 Location: Darmstadt, Germany
Scharnhorst Issue 22  We finally get to take a break from roof related shenanigans and deal with the bow and stern of the ship instead. For these we receive 2 plastic mouldings each which are epoxy-glued together and onto the ends of the hull. This is where the decision to use MDF to form the hull starts to make sense, because fit is absolutely perfect. These parts will make the planking of the hull (should we eventually start it at some point) infinitely easier. I'm usually not a big fan of plastic, but for these sections it makes things so much easier that I'm ok with it. Other options how these sections are done in other ships of this type are ceramic prefabs (prone to break, usually major fit issues) or building up the sections with layered plates of wood then sanding that block smooth (torturous work that usually ends in less than satisfying results)
They look very well detailed as well  great stuff  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Making great progress, all is looking good.... Regards Alan
Progressing nicely Greyhawk! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Looking good. Those bow and stern pieces will save a lot of sanding. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
A similar idea to the U-96, combining wooden planking with plastic sections and mdf frame. It worked well on the U-96.
That's right. It's very close in design to the U96 for now. Scharnhorst issue 23  Back to roofs. This time we receive the first two upper deck plates. Those are just loosely laid down on the hull for now. The designers surprise me again, but this time in a positive way. There are cutouts in the plates to simply stick the deck structures into. Proper Fit and sit of the deck structures is usually a huge pain in the behind so this solution is nothing short of genius.
Scharnhorst issue 24  The next two deck plates arrive and are put in place loosely for now. Note the middle deck structure is the wrong way around because I'm dumb and should be turned around 180 degreees. Good thing that nothinng is glued yet.
Looking good, as for the wrong way round, most of us have done it at some stage in a model. Mark Regards Markwarren (Mark) Admin
She's looking good. Always good to spot the mistakes before glue is applied, as Mark says, we have all done it.
Gaeme
Great looking model  can`t wait for more  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
She's coming along superbly now. Looking forward to next update Happy building David
Its looking the part now. I think those injection moulded bow and stern sections are very good. Happy Modelling
Looking top notch, love watching Warship builds got a few to do but not just yet. Your doing a grand job on her.
Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Thanks everyone Scharnhorst issue 25  The last deck plate is delivered and all of them are now fixed to the hull. Small tabs on the cutouts and edges make it easy to properly align the plates.
Huge model! Nice work!Greetings, Walter
Danke, Walter :-) Scharnhorst issue 26 With the deck plates in place this is the perfect time to finally start planking the hull....  ... so instead we start kitting out the upper deck structures. The middle deck structures curved sections are covered with brass and for the first time it becomes clear why the layered "multi-roof" approach was taken for these. Any portholes instantly become actual holes, no need to fake things with paint or opening them up with a drill. It's pretty ingenious. We also build four ventilation system (?) thingys, to be installed at a later date.
Nice progress Greyhawk, all looking good..... Regards Alan
Wow that is a big ship.What is the length? Looking great
It`s a bit weird not planking and starting to add the etch  still looks excellent  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
