38 Pages «<678910>»
Garth's Black Pearl Options
#141 Posted : 21 November 2017 18:57:28
Lovely work Garth, looks very effective.Love
#142 Posted : 22 November 2017 06:39:23
Hi Guys,
Thanks for looking in and leaving such inspiring comments.
I have been giving my wiring some thoughts and I think I have a better solution. BigGrin
#143 Posted : 23 November 2017 14:37:43
Garth wrote:
Hi Guys,
Hi Garth, check out small scale lights.com for reference. Might not be what you're after, but they're handy to know of for future projects.
Phil W.BigGrin
#144 Posted : 24 November 2017 10:34:04
Hi Phil,
Thanks for that. Will defiantly check it out.
#145 Posted : 04 December 2017 06:10:01
Hi again Phil,
I had a good look at that website, they have really done their homework. I definitely recommend any body who wishes to illuminate their models to check them out.
My only problem is that living in South Africa, with an exchange rate of almost 20:1, compounded by an unreliable postal service, these items become are just too costly. I have to make do with what is locally available.
But, thanks again.
#146 Posted : 04 December 2017 07:16:37
Hi All,
To add more light, I made 3 more lanterns.
I tried a different approach on the wiring this time. I used scrap ribbon cable recovered from an old PC hard drive. This worked much better than the armature wire.
In addition, I fitted a tiny piece of heat shrink around the LED to prevent it shorting on the lanterns body. As with the other lanterns, I applied a blob of clear silicone sealer to the back of the LED and pushed it into the lantern. It’s important to leave this to dry for a couple of hours.
This method worked much better, the entire assemblies seemed much tougher and there was no ‘flickering’ once all was soldered!!!
Whilst the soldering iron was out, I used the opportunity to neaten up the wiring, fit the input wires and the wires that will connect the second decks ‘Buzz Bars’.
#147 Posted : 04 December 2017 09:09:01
Great looking lighting effects Garth, well done.....Drool Drool
#148 Posted : 04 December 2017 10:02:20
I really do like the lighting effects Gatth looks just like candle lanterns from your pictures.
#149 Posted : 04 December 2017 16:40:45
looks great GarthBigGrin the new wiring has made a differenceCool regards PhilCool
#150 Posted : 04 December 2017 21:33:53
Lovely work Garth, looks excellent BigGrin
#151 Posted : 04 December 2017 22:32:14
Looking brilliant, very atmospheric.
#152 Posted : 05 December 2017 01:14:06
Very nice Garth. Love it mate.
Chris Cool
#153 Posted : 08 December 2017 13:01:43
Hi Guys,
Thanks for looking in and for the kind remarks. It's really appreciated.
#154 Posted : 11 December 2017 06:54:22
Hi All
Now for a bit of fun. I have always wanted to have some skeletons in the cells and I finally was able to get my hands on some suitable candidates.
To make the candle, I used a piece of 0.75mm fibre optic. I made a projector using some of off-cut styrene tube with a 3mm LED and the 0.75 Fibre Opric hot-glued into each end.
I cut the optic at an angle to look like a flame and used some old GW Yellow Ink to change the colour of the LED.
I made a table of sorts then drilled a 1mm hole through for the Fibre Optic.
The projector and wires are tacked to the underside of the deck with hot glue.
A note on gluing Fibre Optics. Do some tests first as most solvent based glues damage the Fibre Optic and it can snap. Use epoxy or hot glue to glue them.
#155 Posted : 11 December 2017 13:32:44
Looks so coolDrool Drool great stuffLove Love regards PhilCool
#156 Posted : 11 December 2017 16:05:22
Excellent work Garth. Cool Cool
Love the fun element WTG.
#157 Posted : 11 December 2017 16:22:40
Lovely work Garth, putting some life and soul into it, looks great.BigGrin
#158 Posted : 11 December 2017 23:59:01
What a great addition Garth, looks amazing.....Drool Drool
#159 Posted : 12 December 2017 15:20:45
Fantastic work Garth!Cool Those skeletons really bring the model to life. <ahem> Pardon the pun!LOL
#160 Posted : 22 January 2018 08:32:36
Hi Guys.
Thanks everybody for looking in and for the kind replies.
I've been out of circulation for a while, and seen as I drive a mouse for a living - I avoid the computer like the plague when I'm on leave.
38 Pages «<678910>»
