Great job on the paintwork Phil, looking really good.
pemberg wrote:Great job on the paintwork Phil, looking really good.
Graeme Thank you Graeme!  It's getting there, slowly but surely. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Another superb update Phil  should look great when you start to add all the interior detail  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
tigerace wrote:Another superb update Phil  should look great when you start to add all the interior detail  regards Phil Thank you very much Phil!  Before i start the interiors, i'll be concentrating on getting the outer hull weathered, fitting the rudders, fore & aft planes, prop shafts, propellers and wooden decking. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
This is looking sooo good  keep up the good work. Al
Spal wrote:This is looking sooo good  keep up the good work. Al Thank you very much Al!  Lots more updates to come. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
 Progressing well Phil Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Progressing well Phil Thanks Andy! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Good evening from 'The Dockyard'. This weeks update of my U230 U-boat build log sees the completion of painting the compartments! The attached photo shows the Aft Torpedo Compartment. I had to touch in with matt white around the central support which will eventually house the aft torpedo tube. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Motor Room. This area will house the main motors which drive the propeller shafts. The main motors are electrically driven, power provided via the batteries. To control the electrical supply there would of been two distribution boards, port and starboard. I will model the port side only to reveal more detail. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Engine Room looking aft. I will build the two engines and ancillaries as per the part-works instructions, then make a call if this space requires further detailing. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Engine Room looking forward. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
No2. Battery Compartment. This section is a cut-out rather than a full length view, due to the fact that on each side of it lies 12mm thick MDF supports, fixed during the early stages of this build. I will scratch build several rows of batteries connected by copper wire at a later date. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
No.3 MBT [Main Ballast Tank]. This tank was constantly in use, either empty when the boat was surface running, or full when dived. Within it lies the search periscope housing and mast well. I'm thinking I might add a few touches of rust around the housing when i come to weather this section as it would of spent some time empty, possibly rusting, before being filled again when the boat dived. Above it, the Control Room. This will be painted at a later date when I add the part-works supplied pressure hull sections. These sections have lots of kit supplied details to go on first and as per the Engine Room, I will make a call if further detailing is required. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Forward Torpedo Compartment looking aft. Some of the MDF on the inside I have left unpainted as it will eventually be fitted with bunks and lockers. It also means I use less paint and I've been firing through the stuff lately. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Forward Torpedo Compartment looking towards the bow. This area will get totally transformed, what with all the pipes and valves connecting the different systems to the torpedo tubes. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Complete side view with obligatory washing machine, cooker, kettle and radio.  As I start to progress with the detailing, I promise [ahem] to take all photos with a white background to avoid distraction. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I have yet to paint the top of the U-boat hull [casing] which includes the hatches, capstan and eventually the conning tower. The reason is that I want to lay the wooden planking first. The real U-boats used mahogany planking as it was cheaper to replace a single plank if it was damaged, rather than if fitted with a steel deck. The wood also proved favourable over a steel deck in icy conditions, as the gaps between planks allowed for drainage. I bought some lengths of mahogany from Cornwall Model Boats. Each length is 0.5mm thick and 2.0mm wide, which at 1/48 scale translates to 1" thick and 4" wide in real life. Perfect size. Although I may have to reduce the width to 1.5mm, thus allowing a 0.5mm gap between planks to simulate drainage. It will be a while before i start this section, but it will definitely add a nice contrast compared with the rest of the hull when completed. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
One of the mahogany strips laid out on top of the casing. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Well that concludes this weeks update. Thanks for looking in, have a great weekend and happy modelling! Regards, Phil. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (16)
