Joined: 30/11/2017 Posts: 493 Points: 1,482 Location: South Norfolk
19/06/2017 slow progress today, only the other side completed at the stern, left from yesterday gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
20/06/2017 another day, another couple of planks fitted. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
21/06/2017 Layer started yesterday now completed, droppers also fitted at bow and the first time at stern gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
22/06/2017 and again... another row fitted... only 10 left to fit... gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
23/06/2017 ayer started yesterday now finished at stern, left it to dry overnight with weight to twist properly. Before the next step this layer need to be completed and dried anyway. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
25/06/2017 good progress today 😀 because the bottom of the hull requires different technique. Three complete rows fitted all around the hull. So far the planks were bent (then wait to dry to shape) and then sanded to fit. But now because it's given that how many row have to fit into the gap they are sanded to size and then bent. Also this part doesn't require so big bends (hull becomes flat) hence soaking/bending also quicker, and the planks will dry after they glued/nailed into final position. Countdown started: 7 rows left. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
26/06/2017 one and a half row fitted... slowed down again due to into the thin section of the false keel at the stern no pins can be fitted to hold the planks in place to dry. Clamp placed to make sure the planks dry properly to the keel. This avoids to fit another row. Will continue tomorrow. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
27/06/2017 repetative task done today... row started yesterday completed at bow & stern, new row started in the middle... 4 and a half to go. 🙂 also dropper fitted at bow... finally. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
28/06/2017 nearly there... 😀 another row completed and new one started (only at stern need to complete)... 3 rows to go... gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
01/07/2017 now I can see the finish line... well at least regarding the hull planking 😁. Completed the row from last time plus two more complete rows fitted... ONLY ONE LEFT!!! Yee-haa 😃😃😃 gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
02/07/2017 YES, YES, YES... Mission accomplished... hull planking COMPLETED!!! gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
02/07/2017 building stand made to hold the ship upright while working on it. Before sanding the hull smooth all the gun ports need to be lined. There are 94 of them... 94!!! 😳😱 Plus the two entry ports. The entry ports on both sides and 10 gun ports on one side lined. Also lining strips cut to size... gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
03/07/2017 further 15 gun ports fitted with lining on the right hand side. 69 to go... gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
04/07/2017 further 21 gun ports fitted with lining, with this all the ports on the right hand side completed 😀. 48 to go... 😳 gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
05/07/2017 started to lining the gun ports on the left (port) side, 14 of them done. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
06/07/2017 all the gun ports including the two underneath the gallery now completed with lining. 😊 Next task is to sanding the hull smooth... let's leave it for the weekend... gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
08/07/2017 small gaps and imperfections are filled with milliput. Now need to waitcouple of hours to dry and then will jump onto sanding the hull. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
08/07/2017 Left side of the hull sanded smooth... pfffff... I had enough for today... my hands are in cramp... anyhow, to show the difference here is a picture from the right side and few from the sanded left side... 😊😊 gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
09/07/2017 After further five hours of sanding (five yesterday) the entire hull now smooth like a baby's butt... 😆 I had to hold the sand paper so long that my fingerprints disappeared. I can't unlock my phone only if I type the passcode... :D:D:D Tomorrow the ship will be taken to my workplace to blow out the sawdust from the inside with an air gun 😳💨 gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
09/07/2017 started to cut/form the slot for the keel. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
