35 Pages <1234>»
Laszlo For's Diary Options
gingerale75
#21 Posted : 30 November 2017 17:04:47
19/06/2017
slow progress today, only the other side completed at the stern, left from yesterday
Happy building!
Laszlo
gingerale75
#22 Posted : 30 November 2017 17:05:39
20/06/2017
another day, another couple of planks fitted.
Happy building!
Laszlo
gingerale75
#23 Posted : 30 November 2017 17:06:36
21/06/2017
Layer started yesterday now completed, droppers also fitted at bow and the first time at stern
Happy building!
Laszlo
gingerale75
#24 Posted : 30 November 2017 17:10:16
22/06/2017
and again... another row fitted... only 10 left to fit...
Happy building!
Laszlo
gingerale75
#25 Posted : 30 November 2017 17:14:11
23/06/2017
ayer started yesterday now finished at stern, left it to dry overnight with weight to twist properly. Before the next step this layer need to be completed and dried anyway.
Happy building!
Laszlo
gingerale75
#26 Posted : 30 November 2017 17:15:32
25/06/2017
good progress today 😀 because the bottom of the hull requires different technique. Three complete rows fitted all around the hull.
So far the planks were bent (then wait to dry to shape) and then sanded to fit. But now because it's given that how many row have to fit into the gap they are sanded to size and then bent. Also this part doesn't require so big bends (hull becomes flat) hence soaking/bending also quicker, and the planks will dry after they glued/nailed into final position.
Countdown started: 7 rows left.
Happy building!
Laszlo
gingerale75
#27 Posted : 30 November 2017 17:16:39
26/06/2017
one and a half row fitted... slowed down again due to into the thin section of the false keel at the stern no pins can be fitted to hold the planks in place to dry. Clamp placed to make sure the planks dry properly to the keel. This avoids to fit another row. Will continue tomorrow.
Happy building!
Laszlo
gingerale75
#28 Posted : 30 November 2017 17:20:29
27/06/2017
repetative task done today... row started yesterday completed at bow & stern, new row started in the middle... 4 and a half to go. 🙂 also dropper fitted at bow... finally.
Happy building!
Laszlo
gingerale75
#29 Posted : 30 November 2017 17:21:16
28/06/2017
nearly there... 😀 another row completed and new one started (only at stern need to complete)... 3 rows to go...
Happy building!
Laszlo
gingerale75
#30 Posted : 30 November 2017 17:22:24
01/07/2017
now I can see the finish line... well at least regarding the hull planking 😁. Completed the row from last time plus two more complete rows fitted... ONLY ONE LEFT!!! Yee-haa 😃😃😃
Happy building!
Laszlo
gingerale75
#31 Posted : 30 November 2017 17:23:41
02/07/2017
YES, YES, YES... Mission accomplished... hull planking COMPLETED!!!
Happy building!
Laszlo
gingerale75
#32 Posted : 30 November 2017 17:25:50
02/07/2017
building stand made to hold the ship upright while working on it.
Before sanding the hull smooth all the gun ports need to be lined. There are 94 of them... 94!!! 😳😱 Plus the two entry ports.
The entry ports on both sides and 10 gun ports on one side lined. Also lining strips cut to size...
Happy building!
Laszlo
gingerale75
#33 Posted : 30 November 2017 17:27:25
03/07/2017
further 15 gun ports fitted with lining on the right hand side. 69 to go...
Happy building!
Laszlo
gingerale75
#34 Posted : 30 November 2017 17:28:23
04/07/2017
further 21 gun ports fitted with lining, with this all the ports on the right hand side completed 😀. 48 to go... 😳
Happy building!
Laszlo
gingerale75
#35 Posted : 30 November 2017 17:29:13
05/07/2017
started to lining the gun ports on the left (port) side, 14 of them done.
Happy building!
Laszlo
gingerale75
#36 Posted : 30 November 2017 17:30:47
06/07/2017
all the gun ports including the two underneath the gallery now completed with lining. 😊
Next task is to sanding the hull smooth... let's leave it for the weekend...
Happy building!
Laszlo
gingerale75
#37 Posted : 30 November 2017 17:31:35
08/07/2017
small gaps and imperfections are filled with milliput. Now need to waitcouple of hours to dry and then will jump onto sanding the hull.
Happy building!
Laszlo
gingerale75
#38 Posted : 30 November 2017 17:33:04
08/07/2017
Left side of the hull sanded smooth... pfffff... I had enough for today... my hands are in cramp... anyhow, to show the difference here is a picture from the right side and few from the sanded left side... 😊😊
Happy building!
Laszlo
gingerale75
#39 Posted : 30 November 2017 17:35:09
09/07/2017
After further five hours of sanding (five yesterday) the entire hull now smooth like a baby's butt... 😆
I had to hold the sand paper so long that my fingerprints disappeared. I can't unlock my phone only if I type the passcode... :D:D:D
Tomorrow the ship will be taken to my workplace to blow out the sawdust from the inside with an air gun 😳💨
Happy building!
Laszlo
gingerale75
#40 Posted : 30 November 2017 17:37:08
09/07/2017
started to cut/form the slot for the keel.
Happy building!
Laszlo
35 Pages <1234>»
This page was generated in 0.381 seconds.
