29 Pages «<1112131415>»
karls new victory build Options
#241 Posted : 14 March 2011 16:25:50
My that deck planking infil was quick!
Though another item missing, you've forgotten to drill a third hole in the curved stem approx 5mm below the two already there, see issue 44 or my diary build for 44
#242 Posted : 14 March 2011 21:02:29
waiting for glue to dry on the dolphins,then I get the black and decker out. did'nt you notice the hawsers hole are not drilled either,Flapper
#243 Posted : 14 March 2011 21:58:22
I did, but I thought I was chancing my arm saying so Laugh
#244 Posted : 30 March 2011 11:48:39
I have been looking at mr.t's build,and getting more and more puzzled?
this part build was advertised as museum quality?as mr.t is building by the book this is no critism on the build,only on the design.using brass eyes for railings,?????? there worse to come,the beams that are to show on the upper deck,hope I'm mistaken that is how they are mean't to be,as they are to show,and are a important feature,they were hefty spliced chunks of wood,with ornate columns beneath,I sincerely hope that this will be provided.and it's beginning to look like some serious cost cutting is going on here.
#245 Posted : 30 March 2011 14:11:34
The on-view deck beams are only for the purpose of supporting the deck during construction, at #59 the beams will be cut away and replaced with spliced deck beams.
Deck support pillar's in this area I believe are part of the content.
'Museum quality' is down to one's abilty to be able to build a model to that standard.
#246 Posted : 30 March 2011 15:16:38
Hi Karl,
It looks like its being done the same as they did with HMS Surprise.. Heres what they do..
Chris..
#247 Posted : 30 March 2011 15:41:46
thanks for the info mr.t and chris,keeping big mouth shut from now on Blushing
#248 Posted : 30 March 2011 15:44:56
Its never wise to pre-empt the content or build of any partwork, you simply don't know what's coming further down the line or when it will be supplied beyond that of the next issue or from my future issue's info.
By the way how's your Victory coming along?
#249 Posted : 30 March 2011 15:53:05
thanks for those wise words,mr.t. I think others should think very carefully before altering structures.but I will be replacing the hand rail around that exitway.
#250 Posted : 30 March 2011 15:54:53
Its also a rope handrail on the Caldercraft Victory Wink
#251 Posted : 30 March 2011 16:17:31
sorry mr.t.meant the balastrode.
#252 Posted : 06 April 2011 22:48:13
done the hatches and starting on the tackle for the canons.
#253 Posted : 13 May 2011 20:39:13
started on the rudder,remember guys and gals,the measyrements in the mag to cut the hinge points are added as you go,and start from the bottom.
#254 Posted : 13 May 2011 20:40:13
jonny7england
#255 Posted : 13 May 2011 21:01:25
Looking real good Karl...I'm way behind you and still planking the hull...keep the pics coming mate...
ThumpUp
Son of Bulwark
#256 Posted : 14 May 2011 11:30:25
Hi Karl! Cool
I see 2 hinge plates on the second pintle up from the bottom for the hull fixing, you only need one there mate!.
You will be glad to have some work to do on the Victory this weekend, your other projects will take a back seat todayLaugh
Soon the quarter deck will beckon you ENJOY MATE! BigGrin
#257 Posted : 14 May 2011 16:42:07
thanks for that s.o.b. they were only placed for pics.Confused
#258 Posted : 14 May 2011 16:49:27
as you can see,correct amount of pintals s.o.b.?still installing rudder.
#259 Posted : 14 May 2011 16:52:06
for those of you who have a master cutter,this is how I cut the treads for the stairs,I use a stop to make sure they are all the same length.
#260 Posted : 14 May 2011 16:53:19
