13 Pages <12345>»
Ragusian Carrack, Jack.Aubrey, scale 1:60 Options
#41 Posted : 08 November 2017 21:23:20
Very neat work Jack.
You certainly know your builds well and that looks a good idea to addin those extra strength pieces.
Hope it all continues well for you.
jack.aubrey
#42 Posted : 09 November 2017 09:28:12
Thanks for your positive comments, Tony.
You became a regular follower of my builds and I appreciate this.
But I cannot forget the other forum members that constantly encourage me in practise this hobby.
Thanks to everybody, Jack.
jack.aubrey
#43 Posted : 09 November 2017 10:04:20
Thursday 9 November 2017
New but latest images, with more focus on certain construction details. .
At the moment I am applying a coat of diluted vinyl glue +/- to 50% over the entire structure.
This operation helps to make the surface of the plywood more durable by saturating it with glue and preventing the various pieces from falling or jerking against sanding operations. It should also make the wood less subject to humidity changes, which, in these days here in Calci, is very strong because of recent rains.
Soon I will have to prepare myself to shape the bulkheads with the correct camber and apply preshaped sweet wooden blocks where necessary, especially at bow and stern, to best fix the ends of the planks.
In the idle time I'm trying to finish the second HMS Guadeloupe boat.
Soon, Jack.
01 Ragusian Carrack/07112017/20171107_132826.jpg
02 Ragusian Carrack/07112017/20171107_132916.jpg
03 Ragusian Carrack/07112017/20171107_132926.jpg
04 Ragusian Carrack/07112017/20171107_132953.jpg
05 Ragusian Carrack/07112017/20171107_133005.jpg
#44 Posted : 09 November 2017 11:14:47
Great updates Jack BigGrin lovely work Drool regards PhilCool
jack.aubrey
#45 Posted : 22 November 2017 15:46:25
Tuesday 21 November 2017
It's some days without news from me since my last post because I had to spend several time on other matters. However I have not been completely inactive on this model.
Not a lot but during these days I have:
1) finished the second of the HMS Guadeloupe lifeboats; now only another rather small one is missing, and then I'll finish with these boats;
2) I set up, in the prow area, some filling blocks, made of several layers of poplar plywood glued together; they are now rough, but still to be finished properly;
3) I'm building the stern post, especially at the top, made with 2x5 soft wood strips; also here I just have to refine before applying the last layer planks.
Lastly, some considerations on the kit and subsequent decisions regarding the future tasks for this project.
The wood available in the kit for planking the hull and decks consists exclusively of 4 x 1,5 walnut strips. They are of great wood, even if, for my opinion it's a wood too dark (you can have an idea by looking at the previous post where, in some photos, you can see them on the visible side of some bulkheads).
Obviously, only one planking is planned.
Recalling my previous experience with an identical approach based on walnut planking and evaluating the problems encountered during hull refinement and smoothing, I have considered the pros and cons of using this material.
So I decided to proceed on my way using the double planking technique, also because I found the material I needed:
a) in a model shop near to me (among other things, well-stocked) I bought some 1,5x5 mm lime strips to be used for the first planking; since lime is much sweet than walnut I should be able to work much more easily and quickly; in addition, being them wider strips, I should go furtherly faster.
b) I have found veneer sheets, 0,4 mm in thickness, of CHERRY wood at a timber reseller. It's nearly a century I dreamed to use this kind of wood for a model of mine . . . so I decided right away.
The technique is super tested having used it for two of my previous models and also for several boats, so it's like playing soccer in your own home field . .
Of course I have no pictures of the work done on the carrack to show, but I don't think it's a big loss as there is not much to show. At most, I'll show you a couple of photos of the two Guadeloupe boats . .
01 Brick de 24/Brick by JackAubrey/IMG_20171115_154048.jpg
02 Brick de 24/Brick by JackAubrey/IMG_20171115_154030.jpg
#46 Posted : 22 November 2017 19:26:40
Those little boats look very neatly made.
Is the cherry veneer already cut into strips or do you gave to cut the wood to size yourself?
All sounds like something very special.
jack.aubrey
#47 Posted : 22 November 2017 20:00:50
Hi Tony,
The veneer I bought is in sheets, as shown in the image below. the wood in the photo is chestnut and tanganika. Cherrywood is more dark and red.
I make the strips simply using a spacer jig, a iron ruler and a xacto knife; it's very simple and fast.
Regards, Jack.
#48 Posted : 23 November 2017 09:40:16
Those boats look fantastic. Such tidy work!
jack.aubrey
#49 Posted : 23 November 2017 14:15:25
Thursday 23 November 2017
Some pictures of the work made on the stern, aimed at the construction of the stern post. This element is definitely finished, ready to receive, in due course, the last layer of cherry wood strips.
A view of the inside, left raw . .
01 Ragusian Carrack/21112017/IMG_20171121_152153.jpg
And two exterior views, smooth and ready for the next steps . .
02 Ragusian Carrack/21112017/IMG_20171121_152137.jpg
03 Ragusian Carrack/21112017/IMG_20171121_152143.jpg
The filling blocks in the bow area, still under construction and to be refined . .
04 Ragusian Carrack/21112017/IMG_20171121_152215.jpg
05 Ragusian Carrack/21112017/IMG_20171121_152230.jpg
I have reinforced the tops of the 9th, 10th and 11th bulkheads that could break during the hull manipulations planned in the next steps . .
06 Ragusian Carrack/21112017/IMG_20171121_152201.jpg
That's all, see you soon, Jack.
jack.aubrey
#50 Posted : 27 November 2017 14:30:09
Sunday, November 26, 2017
I'm going to describe the latest developments.
It's not a lot but at this time I'm a little conditioned by the outside temperatures that are starting to decrease and working with the cold inside a garage doesn't fit too much for me. So I work only in the warmer hours and, with the current short days, time is not much.
I have finally finished installing and shaping the bow filler blocks . . since I didn't have usable wood blocks I used poplar plywood elements glued together. Even though this wood is fairly soft, because of the poor quality of the sanding paper I had available, I took more than expected even if at the end I got there.
I'm evaluating a similar solution for the stern, though limited, by doubling the thickness of the last two bulkheads just in the lower zone, this to increase the surface in contact with the planks.
01 Ragusian Carrack/26112017/IMG_20171126_171735.jpg
02 Ragusian Carrack/26112017/IMG_20171126_171743.jpg
03 Ragusian Carrack/26112017/IMG_20171126_171752.jpg
Cheers, Jack Aubrey.
#51 Posted : 27 November 2017 18:05:09
Jack
That is such a clean build it looks wonderful.
jack.aubrey
#52 Posted : 02 December 2017 12:24:42
Thursday, November 30th 2017
The preparatory activities for the hull planking are continuing . .
At the moment I am focused on the prow zone and in particular on the forecastle. Here I saw the possibility of carrying out activities independently from the other areas of the hull, then, having previously assessed the situation, I decided to attack this area, just to "warm up the tires".
In doing so I decided to move away from following the assembling instructions provided in the kit: they were very valid, if not absolutely necessary, in the work phases carried out so far but I think that from now on we can proceed quite freely.
In particular my activities were the construction of the forecastle's top structure, the finishing of the front vertical wall and the application of the deck planks. To do this I used the walnut strips supplied in the kit. However, once again this essence seems to me decidedly dark to cover the decks, so even here I decided to proceed with my own head. This walnut planking will serve as a starting point for covering with self-made strips made with tanganika wood veneer, much clearer than walnut. . so do not look at the strange layout of the strips of the deck I used as a modeling heresy, 'cause it only serves as a background.
Below a bit of pictures of the work done, kind regards, Jack.
01 Ragusian Carrack/30112017/IMG_20171130_174922.jpg
01 Ragusian Carrack/30112017/IMG_20171130_174940.jpg
01 Ragusian Carrack/30112017/IMG_20171130_174948.jpg
01 Ragusian Carrack/30112017/IMG_20171130_174958.jpg
01 Ragusian Carrack/30112017/IMG_20171130_175005.jpg
#53 Posted : 02 December 2017 17:32:46
Great update JackBigGrin you are real skilled modelerBigGrin excellentDrool regards PhilCool
#54 Posted : 02 December 2017 19:59:56
Great progress looks fantastic as always
#55 Posted : 02 December 2017 21:19:21
I do like the coluring on the decking you have done so far. Looks so different to the usual walnut strip wood colour - have you added some additional staining or paint finish? Either way it looks nice but can understand if you prefer a different finish then that is the correct step for you to follow.
Hope it all continues well.
jack.aubrey
#56 Posted : 05 December 2017 13:51:08
Monday 4th December 2017
The weather is definitely getting cold and working in the cold of my garage is not the best . . but the passion and, above all, the wish to see some few planking installed made me overcome this difficulty . . as long as it lasts . . BigGrin
As anticipated I started "to warm up the tires" by applying few planks in the upper part of the forecastle: first there is an area of ​​5/6 perfectly straight planking followed by a larger area of planks, previously bent, which connects to the real stem.
To bend the strips, in limewood 1.5 x 5mm, I used the method of the iron can and the candle, a method that I learned to master at the time of the model of the 12 Apostles and I find it very simple and practical.
From now on I could start to apply the planking on the whole hull, but first I still have to refine and get ready the stern area, in particular with regard to the well known bevel angle.
Below, the usual roundup of images, see you soon, Jack.
01 Ragusian Carrack/04122017/IMG_20171204_182034.jpg
02 Ragusian Carrack/04122017/IMG_20171204_182053.jpg
03 Ragusian Carrack/04122017/IMG_20171204_182114.jpg
04 Ragusian Carrack/04122017/IMG_20171204_182252.jpg
05 Ragusian Carrack/04122017/IMG_20171204_182309.jpg
06 Ragusian Carrack/04122017/IMG_20171204_182327.jpg
jack.aubrey
#57 Posted : 05 December 2017 14:05:19
birdaj2 wrote:
. . . have you added some additional staining or paint finish? . . .
Hi Tony, the wood has not been stained, it is in its natural color, while beautiful, in my opinion it is too dark to cover a deck . . keep in mind that in the real world the wood used for decks was pine or spruce, and the color was clear and after some time became medium grey . .
PS: thanks to all the people following my thread for the continous appreciations . . thanks again, Jack.
#58 Posted : 05 December 2017 17:25:20
Jack
Really loving the planking - very even and smooth.
Understand what you are saying about the decking - that would be very dark as it is but must say i really did like the range of coloures the wood gave.
Nytetrain
#59 Posted : 05 December 2017 23:30:44
Always love your work Jack. Drool Drool This candle and can method you use to bend your planks... could you explain your process a bit more? How do you handle really sharp bends?
Best Regards,
Ron
In the Stash: Losing count...
jonny7england
#60 Posted : 06 December 2017 07:54:27
Looks quite a fascinating build... beautiful planking work and features...Love it!! Drool
13 Pages <12345>»
This page was generated in 0.243 seconds.
