3 Pages 123>
Disabled model builder Options
Monty Dog
#1 Posted : 20 November 2017 13:18:33
Rank: Amateur level 2
I am new to this Forum, and would be very interested to know how many people on the forum have a disability that makes Modeling a bit more of an adventure than those lucky enough to have full abilities.
I have Multiple Sclerosis which has left me with just my right hand to work with, this means that I have to think about ways of holding the parts Im working on. Although I build a lot of plastic kits to keep me occupied I find these large scale screw together models a great help as assembly just requires a good clamping system and a screw!!!
Anyway as this is my first post I would very much like to hear from others on my subject Im on part 35 of the JaguarE type.
Regards Tony
#2 Posted : 20 November 2017 16:05:11
Welcome to the forum Tony. I hope you find the forum a helpful place to be, there is a lot of expertise here.
I'm sure there are many builders who would be interested in the methods you use to overcome your disability (whether disabled or able bodied) as well as others who would be glad to help with any particular problems that may arise for you.
I for one would love to see some examples of your work.
#3 Posted : 20 November 2017 16:41:52
Welcome to the forum TonyBigGrin hope to see some pictures of your buildBigGrin regards PhilCool
#4 Posted : 20 November 2017 17:03:06
Welcome to the forum TonyBigGrin hope your enjoying your Jaguar build so far.
stevegbr
#5 Posted : 20 November 2017 17:09:04
welcome tony, would be great to see some photos of your work. BigGrin BigGrin
#6 Posted : 20 November 2017 17:13:29
Welcome to the forum Tony, I look forward to seeing some of the work you have done soon.BigGrin
CKale
#7 Posted : 20 November 2017 21:42:52
Rank: Amateur Level 1
Hello Tony
It sounds like you're getting on really well with the build. I found the wire wheel to be challenge enough with two working hands.
I haven't got a disability other than aging eyesight but I have found it a lot easier to use a different screwdriver with 8 interchangeable magnetic bits of different sizes, particularly for the frame. It has a wider shaft so easier to grip. I look forward to seeing pics of your build.
#8 Posted : 20 November 2017 22:04:23
Hello Tony.
Welcome aboard.
There are quite a few build diaries of the E Type to peep at for ideas.
If you get stuck, there's plenty of help here.
Roy.
#9 Posted : 20 November 2017 23:23:19
Welcome aboard Tony, hope you enjoy your time with us and look forward to seeing some of your work.....Cool Cool
#10 Posted : 21 November 2017 00:02:36
Welcome aboard Tony.
Enjoy
Cool Cool Cool
Monty Dog
#11 Posted : 21 November 2017 16:01:19
Thank you all for the very warm welcome. I am having a great time building the E type which comes as a relief from my last E type which was from Monogram and took a lot of patience as the kit is very old, infact when I was in Holland in the 60s this kit was brand new, and only £8.00!
With regard to methods I have a small hand vice which was built as an examination piece for an apprentice and I couldn't manage without it.
I will try to put some pictures on the site if I can work out how to do it.
#12 Posted : 21 November 2017 16:17:11
Welcome Tony, look forward to seeing your build progress. Hope you enjoy building it.
Chris Cool
Monty Dog
#13 Posted : 21 November 2017 16:19:46
Tried getting pictures on the page but with no luck, Im using a Macbook which seems to make the job difficult.
Anybody with advice would be welcome.
I notice two images showing but they havent downloaded
#14 Posted : 21 November 2017 16:25:16
Your pictures are way too big.
Max image size is about 145kb
Yours are around 2,000 - 2,500kb.
You need to resize them in a picture editing or paint program.
Roy.
#15 Posted : 21 November 2017 19:26:50
BigGrin Welcome to the forum and enjoy your build
Monty Dog
#16 Posted : 21 November 2017 20:47:17
Roy.
Thanks Roy I must do some resizing asap
#17 Posted : 22 November 2017 12:37:43
Hi Tony, a guide on how to resize and post pictures on the forum is available here
http://forum.model-space....aspx?g=posts&t=244
The pics should be 600x450 pixels which should give you the correct file size for them to visible on the forum without members having to download them.
Hope this helps
Monty Dog
#18 Posted : 22 November 2017 13:05:45
Well Ive read all of the info on resizing photos but most refer to windows, is there a trick i should know when using my Macbook?
Eagle
#19 Posted : 22 November 2017 13:31:03
Red Medal: Red Medal
Welcome to the forum Tony: I have a neck injury that will only allow a limited time to model while looking downwards, so most of my modeling is done standing up with a height extension on my bench to allow me to work looking straight ahead. not the easiest way to work, but better than nothing, one does what he can.
jonny7england
#20 Posted : 22 November 2017 18:17:26
Welcome to the forum Tony...I hope that you enjoy your stay and look forward to seeing your build pictures...
ThumpUp
3 Pages 123>
