Thanks again for the encouraging comments, guys!
I added the pin rails at the foremast - the problem was that with building the gratings more narrow than in the instructions - the pinrails were shorter and so i had not very much space for the Pins.
I hope this won`t haunt me once the rigging comes up.
Also i attached the two cannons to the deck - didn`t want them just standing there - so i added some securing ropes - don`t know if that`s correct - but it would make sense.DaDokta attached the following image(s): Greetings, Walter
It occurred to me that sometimes some of the pics are shown in a different orientation, also sometimes i have to reload pages several times to be able to see all pics.
Do you have these problems as well?Greetings, Walter
DaDokta wrote:It occurred to me that sometimes some of the pics are shown in a different orientation, also sometimes i have to reload pages several times to be able to see all pics.
Do you have these problems as well? Hi Walter, having to refresh the page to view images is a known problem and is with the IT team. The pics showing in a different orientation is not something I have experienced or seen before nor has this been previously reported. Will take a look and see what I can find..... Regards Alan
Maybe the wrong orientation was my fault. But thanks Alan!Greetings, Walter
Next up was the gratings and pin rail around the main mast.DaDokta attached the following image(s): Greetings, Walter
Beautiful work as always Walter.
Thanks Graeme!
The last four of the cannons were attached.DaDokta attached the following image(s): Greetings, Walter
Moves on another stage and looking very good indeed. Happy Modelling
Joined: 04/10/2016 Posts: 135 Points: 412 Location: Newcastle U.K.
Looking great Walter. Keep the pictures coming. Excellent work. Alan. Today is the tomorrow you wished for yesterday!
Nice update Walter. Coming along very nicely. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Loving the work you have done there Walter...Like it very much!!  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
As always - thanks for your nice comments!
I invested much thought in how to make the binnacle. I used Mike`s enhancement parts - but wanted to enhance them further.
As you can see i first cut out the middle part so that only the frame remained.DaDokta attached the following image(s): Greetings, Walter
Then i produced the two compasses out of 3x3mm wood. I decreased the picture of a compass-rose in size, printed it and glued in on top.
The lantern i made out of a toothpick.
The three part were glued on a piece of wood and inserted into the frame.DaDokta attached the following image(s): Greetings, Walter
At last i added the PE-parts and the windows.DaDokta attached the following image(s): Greetings, Walter
Nice job Walter, looks brilliant!
Walter Very detailed little part which will add a lot to the overall build. Happy Modelling
Lovely detail work Walter  impressive. Al
 Very nice work Walter Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Walter. Great work on the compasses. look forward to the next update. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Nice work Walter. Looks fiddly but you've done a good job. Alan. Today is the tomorrow you wished for yesterday!
Guest (6)
