Security of the dome panels Options
philljwarren
#1 Posted : 19 November 2017 20:12:35
Rank: Amateur Level 1
Just wondered if an admin could answer this - should we be concerned about the dome panels only being held on by adhesive tape? Just wondered about how these would fare over time. Having a dome panel fall into the main body of the model because the tape lost its stickiness (or as is more likely in my house - because little fingers pushed it in) would be a pain.
tschwand
#2 Posted : 19 November 2017 20:54:39
I think you will also get some outward push by the frame. I think those two things will work, but I agree, would rather see the non moving pieces a little more firmly held in place.
coldsweat
#3 Posted : 19 November 2017 20:59:12
Rank: Amateur level 2
I thought about this issue when I first looked at the build images, however I'm sure that the intricate dome 'skeleton' that we've been building will hold the pieces tightly & securely in place.
The double sided tape looks like it's main job is to just to hold the inserts in place during the assembly process & alignment.
#4 Posted : 19 November 2017 21:13:10
The double sided sticky tape adhesive is strong, care must be taken when placing the panels into the dome as it is not easy to adjust once in place.
#5 Posted : 19 November 2017 21:46:20
BigGrin As Mark has already said the tape is very strong and also the top of the skeleton dome has a key slot that matches the metal dome key slot. Once in its correct position it is a tight fit and all the panels so far supplied are supported by the skeleton and will not be pushed out by pressing on the outside.Cool
semaj
#6 Posted : 19 November 2017 21:51:54
just to add, step back a moment. your building a model, not a toy. its a very expensive one at that. keep it away from children.
Building:
Complete:
Lacutas
#7 Posted : 20 November 2017 19:20:49
A model that has numerous moving parts and an interactive app to control it. I think leaving it on a shelf is a shame, and loose parts is a valid concern.
philljwarren
#8 Posted : 20 November 2017 21:38:58
Sorry, but there's no way I wont be sharing this with my 6 yr old son who's a massive star wars fan. Part of the fun of building this is to see his reaction when it's finished BigGrin
semaj
#9 Posted : 20 November 2017 21:56:29
i totally get that. dont let them bash it about is all im saying.
Building:
Complete:
This page was generated in 0.259 seconds.
